Old 02-10-2008, 10:41 PM   #1 (permalink)
Unhappy foglights + A/C problem
so i got my foglight and hids installed like 2 months ago and everything worked fine. but suddenly a few days ago i started to notice that my A/C or air was not turning on. There were no lights or anything for the air. Then as i was putting gas just the other day, i also noticed that my foglights wernt working now as well. But my HIDs are still working. Is the reason my A/C wont work due to my fogs ? does it have anything to do with connecting the fogs, that the wires must have caused something to the A/C ?? what can I do to fix this problem ??? helpp !!
Last edited by y0ungxhollaa; 02-10-2008 at 10:44 PM. Reason: added more details.,,
y0ungxhollaa is offline   Reply With Quote
Old 02-10-2008, 10:47 PM   #2 (permalink)
Jeremy
check your fuses
jeremy0203 is offline   Reply With Quote
Old 02-11-2008, 03:55 PM   #3 (permalink)
okay yeah i did and that was the problem. but once i replaced it with the other 10 amp fuse, in less than 5 sec it blew again. so im guessing the guy who installed the fogs connected it with the A/C as well and its putting out too much power. then i tried the 15 amp fuse and wow this one worked and didnt blow. my only problem is that honda says not to use higher than what they recommended so i just took it out to avoid a major electrical problem...so to get this problem fixed, where should i connect the fogs instead to balance out the power???
foglights 2007SilverCivicSI Mechanical Problems & Technical Chat 14 10-06-2007 01:52 AM
oem foglights vs k2 foglights TRANCEBOY Lighting, H.I.D.'s, & Neon 2 07-09-2007 09:13 PM
foglights civic4ever28 Lighting, H.I.D.'s, & Neon 9 10-24-2006 10:43 PM
Help with foglights? yankeesbat17 Lighting, H.I.D.'s, & Neon 2 09-12-2006 10:54 PM
Foglights Silver8th Lighting, H.I.D.'s, & Neon 29 04-04-2006 04:15 PM
