Old 02-08-2008, 01:34 PM   #1 (permalink)
KraziAzn's Avatar
David
Engine Light...randomly go on and off
yah...
i got my K&N intake installed yesterday...and after that...the engine light would go on and off...
randomly....
any idea what i should do??
KraziAzn is offline   Reply With Quote
Old 02-08-2008, 01:40 PM   #2 (permalink)
Ct_Sidan07's Avatar
reset the ecu by unconnecting the negative wire (black wire) on the battery...do this for a few minutes and the problem should go away
Ct_Sidan07 is offline   Reply With Quote
Old 02-08-2008, 01:41 PM   #3 (permalink)
ELDUU's Avatar
Originally Posted by KraziAzn View Post
yah...
randomly....
I'm guessing that the sensor might either be put on wrong or it came loose, try adjusting it a bit see if it helps?
ELDUU is offline   Reply With Quote
Old 02-12-2008, 01:17 AM   #4 (permalink)
KraziAzn's Avatar
David
alrite im not too good with cars...
how would i adjust it? do i just unscrew it and screw it back on??
that simple?
Old 02-12-2008, 03:05 AM   #5 (permalink)
ELDUU's Avatar
that could work, could of come loose or something, disconnect your battery's negative also for like 20 sec and put it back on and it should be off (CEL).
Old 02-14-2008, 10:31 PM   #6 (permalink)
KraziAzn's Avatar
David
did that.. CEL went off for about 30 miles...and came back on...
i should probably get it checked out?
Old 02-15-2008, 12:12 AM   #7 (permalink)
My guess is that there is an air leak. Make sure all of your connections are tight.
bluesunit is offline   Reply With Quote
Old 02-15-2008, 12:18 AM   #8 (permalink)
BROCCOLI
Gonzo's Avatar
NOTHING BUT BROCCOLI
How often does it go on and off? How much time between those intervals?
If it is going on and off fairly rapidly (more often than twice in an hour) that is pretty odd.
As the guy above suggested, check all your hoses, make sure they are tight, and check your wiring to make sure it is all secure. Also check the seating of your maf sensor. Be sure it is sitting flat and the o-ring on it isn't pinched or anything.
Did you mess with anything else than installing the intake that day?
Gonzo is offline   Reply With Quote
Old 02-15-2008, 12:49 AM   #9 (permalink)
KraziAzn's Avatar
David
1. It stays on... it never turns off
2. the hose that connected to the engine...is not ziped tie... but i check its out pretty tight
3. I got a local shop to install.
Old 02-15-2008, 12:59 AM   #10 (permalink)
BROCCOLI
Gonzo's Avatar
I would make sure you get some clips for all the hose on both ends.
The shape and size of the oem clips are designed so they pinch the tubes and hoses right behind the lip or flange of where they connect.
Zip ties I don't know that I would suggest. They are more narrow than clips and they don't really provide pressure in the same way a spring clip does. Plus zip ties aren't really reusable and I would imagine are more susceptible to failure.
Just my two cents.
Hope everything gets settled. If you find out what the problem was be sure to post it. Good luck!
Old 02-15-2008, 03:09 AM   #11 (permalink)
KraziAzn's Avatar
David
alrite thnxs..ill buy some clips later this week see how it goes
Old 02-15-2008, 02:07 PM   #12 (permalink)
i got same problem with CEL it randomly goes on and off, usualy i noticed when it`s warm outside it`s on, and when it`s wet and cold (around -10C) outside and air is humid, the light sometimes goes off. was wondering if there`s any way to get a code readings.
echamsou is offline   Reply With Quote
Old 02-15-2008, 05:54 PM   #13 (permalink)
Adlh29's Avatar
Adam
Try a Scangauge2
Adlh29 is offline   Reply With Quote
Old 02-15-2008, 06:35 PM   #14 (permalink)
BlackSi10's Avatar
FG Squad Member #350
take it up to auto zone and they will check it for free and tell you what it says
BlackSi10 is offline   Reply With Quote
Old 02-15-2008, 07:11 PM   #15 (permalink)
BROCCOLI
Gonzo's Avatar
Yeah, lots of auto part stores will scan your car for you. Autozone and Advance definitely will. Pep Boys probably would to (bleh...)
There is a pretty unlikely chance the scanner may not know what the code means. Some scanners know lots of codes and will display the name and meaning, but crappy scanners won't display the meaning or might now know the meaning for manufacturer specific codes. In that case it will still display the actual code which you can write down and look up later online.
Old 02-18-2008, 08:13 PM   #16 (permalink)
KraziAzn's Avatar
David
rofl no ty...
they're were gonna charge me 250$ to install my long ram...
i got it done at a local shop for 100$..
and i checked the hoses again...i found out i was missing 2 clamps! omg i feel so dumb...
but yah i went to autozone today...lawl...and but clamps...now im gonna resetting the ECU as i type?
so ill update u guys in a bit
Old 02-18-2008, 09:49 PM   #17 (permalink)
HondaTune's Avatar
Wow..... Im just keeping up w/ this thread to see if anyone here will finally guess it..
This is sooo easy lol, blah.
heres the the HINT.
what happends to a obd2 car when you disconnect the MAS - Mass Airflow Sensor lol....
If that doesnt give it away then .
ok nvm ill stop being a dick, Clearly the "shop" that did it for you are some un-legit bastard that didn't clear the code.
When you disconenct the Mass Airflow Sensor or (MAS) You will throw a check engine light. Also you will throw a check engine light if there is a air leak ANYWHERE in the breather or so..
But most likely since the "shop" hopefully knows how to install a intake, then its just the MAS code that needs to be cleared.
If your broke come over here to cali to my school ill clear the code for ya, Good luck. Let me know what happnds
HondaTune is offline   Reply With Quote
Old 02-20-2008, 10:40 AM   #18 (permalink)
KraziAzn's Avatar
David
heres the the HINT.
lol yah my damn light went back on...
im guessing its the code...how da hell do i clear it? come to u? or go to honda?
Drivers side airbag went off randomly!! black07coupe Mechanical Problems & Technical Chat 31 01-18-2008 04:06 AM
Engine Check Light................ NoMoreHonda Mechanical Problems & Technical Chat 19 09-18-2007 10:47 PM
VSA and engine light Negutiv Mechanical Problems & Technical Chat 5 08-09-2007 01:45 PM
Engine Light, PLEASE HELP jynxlee317 Mechanical Problems & Technical Chat 13 07-23-2007 08:08 PM
Check Engine Light DC2006CivicEx Mechanical Problems & Technical Chat 2 04-06-2007 09:54 AM
