Old 02-06-2008, 11:13 PM   #1 (permalink)
Parallel Parking
Not really sure what noises to expect, except from what I've come across on here. But I have recently purchased an 06 sedan and noticed when in reverse and turning the wheel, i.e. parallel parking there is a singular click noise once the wheel is turned and reverse in motion. Anyone else experience this. Thought it was the brakes adjusting or resetting but it only happens when the wheel is turned and in reverse. Also the brake noise which I am told is normal only happens from initial take off of park to drive. Thanks for your help it is greatly appreciated!
jlav is offline
Old 02-06-2008, 11:25 PM   #2 (permalink)
faptastic... pew pew pew
rippars's Avatar
Ryan
click noise coming from the suspension? if so check to see if your vin number falls within those listed in this tsb: Popping from front suspension solved!!!!!!!! TSB!!!!!!!!
06 asm si
Teh Ryan's are up to it again: I Failed In Mah Pants, Burrito Bowl Duece Meet Thread
Originally Posted by firmhonda
2fast is a chick?!? WTF?
rippars is offline
Old 02-07-2008, 07:01 AM   #3 (permalink)
Thanks for your help, why would this noise only happen in reverse though? I will have to get it looked at during the next oil change.
jlav is offline
Old 02-07-2008, 08:43 AM   #4 (permalink)
I also get this noise ONLY in reverse.
asndragonboii is offline
Old 02-07-2008, 06:23 PM   #5 (permalink)
this sounds like it could be it.
Causes of Honda Brake Click or Groan
jlav is offline
Old 02-07-2008, 08:14 PM   #6 (permalink)
Thx for the link. The Brake Groan is what i noticed too before. Had no idea what the sound was.
The link doesnt answer the question of the CLUNK when starting to drive in reverse
parking M1C. MON5T3R California South 21 11-05-2007 06:28 PM
cool way of parallel parking ugination87 Water Cooler 1 05-11-2007 04:11 AM
Italian Job - An Italian Woman trying to Parallel Park modoko Water Cooler 4 03-15-2007 06:05 PM
Honda - Automated Parallel Parking GeezerSi Water Cooler 0 02-23-2007 02:47 PM
Parking without parking brake (AT) amirh Mechanical Problems & Technical Chat 4 12-20-2006 11:12 PM
