Old 02-06-2008, 08:56 PM   #1 (permalink)
Honda just towed my car, FUEL INJECTOR?
Started the car this morning and imediatly noticed the car was misfiring. I called honda and they sent the wrecker. Sure enough, #1 fuel injector is DEAD? Anyone else have or heard of this issue. I was planning on some mods in the future that will require that the injectors work properly and I dont know if I should loose faith in these things. Car only has 4600 miles and is stock (07 si sedan). I told the service advisor to check the tranny for the same reason as everyone else and she said there were no service bullitens for my car??? I have the window rattle(known issue), 3rd gear pop out (known issue), and now a busted injector..(door handle is next...sticking really bad). WHAT HAPPEN TO MY FAVORITE COMPANY?
civicsoul is offline   Reply With Quote
Old 02-07-2008, 12:19 AM   #2 (permalink)
fox
fox's Avatar
Andrew
my door handle would stick a little too, just get some spray white lithium grease and get it into the moving parts, try and keep it off the outside paint. sorry to hear about the fuel injector. though i'm sure they will replace it for free. and if you have any problems with them and technical service bulletins, ask someone here for the scan of it, print it oout and show them. that's pretty hard to deny. they probably thought you were looking for a TSB on the fuel injectors. Good luck!
fox is offline   Reply With Quote
Old 02-07-2008, 12:29 AM   #3 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
I think one other guy had the same problem.
Originally Posted by NBPRudy View Post
:failmyharryballs:
http://killyourself1.myminicity.com/env build my city.
Zeuceone is online now   Reply With Quote
Old 02-07-2008, 08:37 AM   #4 (permalink)
mischief316's Avatar
Rude
mischief316 is online now   Reply With Quote
Old 02-07-2008, 01:34 PM   #5 (permalink)
how do I get a scan of the tsb's? I really am at the point where I am going to fax it to them and hand it to them and explain to them that they need to do there job!
Old 02-07-2008, 03:11 PM   #6 (permalink)
BigT's Avatar
What mod wouldn't require your injectors to work properly?
You are the first I have read about with this problem. Injectors are pretty simple and I think there are only a few companies who actually manufacture them. Like anything it is possible to get a bad one. But I doubt you will have to worry about them being an ongoing problem.
Sorry to hear about all your troubles, hope it all works out.
BigT is offline   Reply With Quote
Old 02-07-2008, 05:34 PM   #7 (permalink)
fox
fox's Avatar
Andrew
i don't know who, but i would imagine some one has the TSBs as a printout of PDF or something, bump for proper TSBs.
Old 02-07-2008, 06:00 PM   #8 (permalink)
saiaba's Avatar
Ryan
wow sounds like problems people were having back when I had my VW.
saiaba is offline   Reply With Quote
Old 02-07-2008, 06:38 PM   #9 (permalink)
Forced Induction needs reliable injectors.... misfire on n/a, KABOOM on boost! And I really need the TSB's, they are ignoring the tranny issue
fuel cell honda car GlxyGry06Si Water Cooler 6 11-20-2007 12:22 AM
Fuel injector cleaner? jpv027 Mechanical Problems & Technical Chat 6 01-09-2007 07:22 PM
CHECK YOUR CAR, if it gets towed! Rommy Garage 15 05-10-2006 03:38 AM
Fuel injector question onefastsi Forced Induction And Nitrous 0 04-29-2006 01:50 PM
