Old 02-04-2008, 11:20 PM   #1 (permalink)
VTEC...i-VTEC??
I been hearding a lot people debate at my work place about the VTEC and i-VTEC, some said VTEC is better and some said i-VTEC is better. So I can get the info to shut them up...Hate and tried of this and that at work lol...
xxiong12 is offline   Reply With Quote
Old 02-04-2008, 11:25 PM   #2 (permalink)
Ass Turtle's Avatar
I would like to know the answer to this to. Also, What makes a VTEC, a VTEC?
Ass Turtle is offline   Reply With Quote
Old 02-04-2008, 11:25 PM   #3 (permalink)
vtec is kick ass but i-vtec is MORE KICKASS . . . the i stands for intelligent basically this means that while on the vtec lope the motor advances or retards the cam angle to give you the OPTIMUM lift duration giving you the best performance givin they driving conditions . . . at full throttle it advances it as much as possible to give you the longest duration if your just kinda playing around and are using the whole rpm range but only at half throttle its not going to keep the valves open all they way for as long as it can its going to sense how your driving and open the valves accordingly . . . make sense? where as regular vtec is just set . . . on only get a set valve duration . . . you have vtec and non vtec thats it
mitsukaiSI is online now   Reply With Quote
Old 02-04-2008, 11:28 PM   #4 (permalink)
chugiboi's Avatar
chue hang
vtec = valve-timing-electronic-control
i-vtec = intelligent-valve-timing-electronic-control
just one word or one letter extra, i'm not too sure which one is better either.
chugiboi is offline   Reply With Quote
Old 02-04-2008, 11:29 PM   #5 (permalink)
vtec stands for Variable Timing w/ Engine Control. on a vtec cam there are three lobs. . . primary , secondary, and VTEC lobe. . . the ecu is where the engine control part comes in as you accelerate thru the gears. the engine is on the primary lobe. . . at a set rpm . . . i believe its 3500 in the k20z3 the cams switch to the second lobe that is bigger and gives you more air flowing thru the motor. . . then at 5800 rpms the cams switch the the third lobe which is the biggest lobe (vtec lobe) and is similar to a race cam in profile. . . this lobe gives you maximum air inlet to give you crazy big explosion to transfer more enegery thru the drivetrain to make you go faster. . . the primary and secondary lobes are econo-lobe. . . they are for saving gas for daily driving . . . vtec lobe is for maximum power and acceleration . . . its the fun lobe
Old 02-04-2008, 11:37 PM   #6 (permalink)
Tod
Do not read this post... please!
First VTEC stands for Variable valve Timing and Lift Electronic Control.
Second, there is not a set of lobes that activates at 3500 RPM...
Solo2EG is offline   Reply With Quote
Old 02-04-2008, 11:37 PM   #7 (permalink)
Ass Turtle's Avatar
Thats, what i figured, But what makes it so different? Is it just that lets my old jeep, that hits powerband at like 4000 rpms, only has Two cam lobs?
Ok im done thread-jacking! haha
Crap just saw post above mine, now im all confused! lol
Old 02-04-2008, 11:45 PM   #8 (permalink)
yes there is . . . 0-3500 rpms is on primary lobe 3500 to 5800 is secondary lobe 5800 to redline is vtec lobe . . . have you ever messed with vtec cames befor? if you had you would know that
Old 02-04-2008, 11:46 PM   #9 (permalink)
and how does VVTLEC = VTEC???
Old 02-04-2008, 11:48 PM   #10 (permalink)
El Sė's Avatar
Lawrence
VTEC - Wikipedia, the free encyclopedia I'm by no means a pro on this. I have a general idea of how it works, but so you can get a more thorough understanding check this link out.
El Sė is offline   Reply With Quote
Old 02-04-2008, 11:49 PM   #11 (permalink)
El Sė's Avatar
Lawrence
cause VTEC is easier to say.
Old 02-04-2008, 11:52 PM   #12 (permalink)
chugiboi's Avatar
chue hang
very funny people, don't get VTEC and V-VTI or whatever mix up together.
VTEC stand for Variable Valve Timing and Lift Electronic Control, but honda took out a couple of letters to make it shorter and sound nicer.
Old 02-04-2008, 11:53 PM   #13 (permalink)
udumkid's Avatar
Rene....
The I-vtec combines the operation of V-tec and VTC system. The VTC system allows continous(sp) adjustment of the intake cam shaft phase(position related to the crankshaft) over a range of +/- 25 degrees(advance or retard timing).
udumkid is online now   Reply With Quote
Old 02-04-2008, 11:57 PM   #14 (permalink)
krazyhusky's Avatar
Alex
I-Vtec All The Way!! IMO
krazyhusky is offline   Reply With Quote
Old 02-04-2008, 11:59 PM   #15 (permalink)
i second that
Old 02-05-2008, 12:00 AM   #16 (permalink)
El Sė's Avatar
Lawrence
There are 3 lobes per cylinder but only two profiles, non-VTEC and VTEC no inbetween. i believe the two smaller lobes control each valve for the cylinder and when the crossover happens, the larger lobe takes over both rocker arms.
Old 02-05-2008, 12:02 AM   #17 (permalink)
i believe it is edmonds that writes that has the rite up of their test drive of the 06 si and they comment on the difference in intake note when the motor switches to secondary lobe at 3500 rpm
it might be a different company but im pretty sure it was edmonds
Old 02-05-2008, 12:05 AM   #18 (permalink)
udumkid's Avatar
Rene....
Also, at moderate speeds the I-vtec advances the cam timing for increase valve over lap, creating an internal Exhaust Gas Recirculating(EGR) affect. At the same time, the lift of the intake valve is reduce to achieve a strong swirl effect in the combustion chamber the combine swirl effect an internal EGR effect provides for a highly efficient combustion process, which eliminates the EGR system.
Old 02-05-2008, 12:12 AM   #19 (permalink)
Si Speed 317's Avatar
Dan
i-vtec. Do you?
Si Speed 317 is online now   Reply With Quote
Old 02-05-2008, 12:16 AM   #20 (permalink)
Elitist Si Driver..
Chase's Avatar
Chase
why yes I do!
Chase is offline   Reply With Quote
SOHC i-Vtec/ Vtec FTW! Typerx7 Bolt-Ons And All-Motor 34 12-17-2007 09:39 PM
Vtec or no Vtec ? you decide lol devoi California South 2 12-10-2007 04:39 AM
vtec tbeers Mechanical Problems & Technical Chat 17 05-29-2007 04:25 PM
HONDA'S VTEC,VTEC3,I-VTEC,*NEW*I-VTEC,I-DSI AND ASIMO BATANG CITY JAIL Introduction & Pictures 4 04-04-2007 11:30 PM
is this vtec? GETxERxDONE Civic Coupe And Sedan 14 01-24-2007 05:46 PM
