Old 02-03-2008, 11:20 PM   #1 (permalink)
Tapping noise coming from Engine bay
Hey guys, I have a 2006 Honda Civic DX-G Automatic and I'm noticing some unusual tapping noise coming from the engine bay. I began noticing this noise around Monday just after I started my car under temperatures that dipped as low as -30-35 degrees celsius (-26 F). This noise seems to dissipate once the car temperature reaches 5 bars and vibration from the car aren't felt anymore. Has anyone else been experiencing the same problems with their Civic. What could this problem possibly be? By the way, the oil life is at 50% (5000 km).
TheSpecialist is offline   Reply With Quote
Old 02-03-2008, 11:27 PM   #2 (permalink)
c130turboprop's Avatar
DO A SEARCH!!!!!!!!!!!!!!!! this has been discussed many times, its the injectors, it is fine....
c130turboprop is offline   Reply With Quote
Old 02-03-2008, 11:28 PM   #3 (permalink)
Michael
What is the weight of your oil?
Street2uned is offline   Reply With Quote
Old 02-03-2008, 11:29 PM   #4 (permalink)
Michael
There are other factors that could play into it NOT being the injectors. Go be an asshat somewhere else and give the new guy some respect.
Old 02-03-2008, 11:29 PM   #5 (permalink)
JZILLA's Avatar
yeah your fine everyones civic does it
JZILLA is offline   Reply With Quote
Old 02-03-2008, 11:30 PM   #6 (permalink)
Michael
With temps being that low, it could be other parts of the motor that are making some noise as they warm up. Someone that has experienced this in similar conditions might be more helpful.
Old 02-03-2008, 11:33 PM   #7 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
When plastic gets that cold, it's bound to rattle somewhere. If you notice performance problems, bring it to the stealership.
msjwild3 is offline   Reply With Quote
Old 02-03-2008, 11:34 PM   #8 (permalink)
it was about zero degrees where i live last weekend and my injectors go crazy when its cold, so i'm probably like 99.3 percent sure thats what it is. not qite as cold as it is where u r, but still, i'm sure they were makin some noise then with it that cold...
Old 02-03-2008, 11:40 PM   #9 (permalink)
I came on to this website before logging on so the search option wasnt available to me. Now that I see it, I will use it. Sorry to those of you who I upset. Thanks for your help. By the way, Im using factory oil. I believe its 5w-20.
Old 02-03-2008, 11:41 PM   #10 (permalink)
Michael
repped
Old 02-04-2008, 12:08 AM   #11 (permalink)
Jason
SHUT THE F*** UP NOOB!!
to the OP:
dont let the that dipstick (c130) discourage you from asking questions you don't know, provided that you did do a search first and still could not find the answer.
Weird noise coming from engine projek7 Mechanical Problems & Technical Chat 49 09-11-2008 09:51 PM
Rear wheel tapping noise Grimey Mechanical Problems & Technical Chat 11 06-12-2008 07:16 PM
Tapping/rattle coming from the front passenger seat of my Si Sedan Grimey Mechanical Problems & Technical Chat 10 08-23-2007 03:27 PM
engine bay dnbsi Detailing 1 04-16-2007 06:18 PM
civic road noise/engine noise californiabass Suspension and Brakes 11 06-14-2006 11:39 PM
