Old 02-02-2008, 08:51 PM   #1 (permalink)
2008 Ex Coupe
I need your some help here. I considering buying a 08 EX Coupe and from reading the Forum I am concerned about all the problems owners are experiencing with their Civics. I have been a loyal Honda owner and have 230k on a 91 Accord. It's time to move on.
Thanks
dogred is offline   Reply With Quote
Old 02-02-2008, 08:59 PM   #2 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
The only problem is the third gear on Si's. Otherwise your good to go!
msjwild3 is offline   Reply With Quote
Old 02-02-2008, 09:00 PM   #3 (permalink)
datbacker59's Avatar
Its a Live2Hustle Thang...
ex coupe is great buy do it. then tint it. then cruise
datbacker59 is offline   Reply With Quote
Old 02-02-2008, 10:48 PM   #4 (permalink)
08WhiteCivic's Avatar
ya i have an 08 coupe LX and i love it. Its an amazing car.
08WhiteCivic is offline   Reply With Quote
Old 02-03-2008, 09:46 AM   #5 (permalink)
BigT's Avatar
Welcome to the site.
For what it's worth I have a '07 EX and haven't had any problems so far (4,800 miles).
Look at it this way, if you ever have any problems they have probably been discussed here and you can get help and advice with the problem.
BigT is offline   Reply With Quote
Old 02-03-2008, 09:50 AM   #6 (permalink)
Devin's Avatar
Devin Flannery
except for me, I have a 2nd gear problem...
Devin is offline   Reply With Quote
Old 02-03-2008, 10:28 AM   #7 (permalink)
ive been having some tranny problems in my ex (5800 miles) and also multiple electronic problems, navi screen staying bright after headlights are on, radio controls on steering wheel malfunctioning, and a few other minor things here and there, other than that i am only contempt with the car.
catfish80 is offline   Reply With Quote
Old 02-03-2008, 11:16 AM   #8 (permalink)
Mark Fisher
I have a 2007 LX, which is very similar to the EX. I have noted the following:
The drive by wire function that is in new Civics is not that great. Sometimes there is a hesitation when accelerating from a stopped position, or after coasting.
I have found that the idle can be somewhat rough, which has been discussed here at great length. The problem may be related to a low idle speed set point (~650 rpm in my case), though that is speculation.
When I am sitting at a stop light and the air conditioner compressor clutch engages the car shakes for a second as the voltage regulator adjusts to the load on the electrical system. This does not happen when the car is moving. Again, I feel that the idle speed is too low and may be contributing to the problem.
My fuel economy has averaged ~22 mpg, but I do a lot of city driving in stop/go traffic with the air conditioner on.
Finally, the transmission can be a bit quirky at times. Shift points seem to be somewhat off at times, which is probably due to the drive by wire control in my opinion. I have found that a mix of 1/3 Amsoil ATF and 2/3 Honda Z1 has improved shift quality, but a lot of folks will tell you to only use 100% Z1.
My advice: Consider looking at other makes and models before you buy a Honda Civic. If I had it to do all over again I might have bought a VW instead.
mfisher1967 is offline   Reply With Quote
Old 02-03-2008, 01:22 PM   #9 (permalink)
very nice car overall.. buy an auto tranny save yourself the headache.. i should have myself.. go for it if you get a good deal
08blacex is offline   Reply With Quote
Old 02-03-2008, 05:40 PM   #10 (permalink)
Jason
honestly, it just depends on the car you buy (ie when/where/etc it was made). as some people state, they are having from minor to major problems. there are those fortunate ones, like me, who happened to buy a civic Si with no problems whatsoever and does not give the driver any problems at all.
Old 02-03-2008, 05:41 PM   #11 (permalink)
Jason
honda's auto trannies are not that great
Old 02-04-2008, 01:06 AM   #12 (permalink)
06CivEXJon's Avatar
Jon
Where did you hear this from? and is it normal for the AT in the civics to go into Neutral without using the shift lever? like just moving the lever freely from D to N? j/c
Old 02-04-2008, 10:19 AM   #13 (permalink)
boltuprite's Avatar
Gary
06 EX coupe here. So far it's the best Honda I have owned (this is my 4th one)
boltuprite is offline   Reply With Quote
Old 02-04-2008, 10:19 AM   #14 (permalink)
boltuprite's Avatar
Gary
Old 02-04-2008, 11:29 AM   #15 (permalink)
Agreed. However, Honda did have problems with the previous 2 generations of AT in the accords with v6 engines mostly. For the most part their 4 cyl MT's including the civics have been pretty reliable. (Exc the SI's with 3rd gear issues IMHO)
magbarn is offline   Reply With Quote
New 2008 Civic EX Coupe drummerlauw Introduction & Pictures 4 11-18-2007 06:45 PM
2008 Si Sedan or 2008 Accord V6 Coupe? SisedanPR Garage 18 11-09-2007 12:39 PM
2008 Altima SE Coupe V6 vs. 2007 Civic Si Coupe jsp2470 Civic SI 16 05-24-2007 07:52 AM
2008 TSX coupe ezcivic type r Photoshop 4 07-21-2006 12:26 PM
2008 TSX coupe? ezcivic type r Garage 31 07-21-2006 12:07 PM
