Old 02-03-2008, 12:37 PM   #21 (permalink)
Szwaboski's Avatar
Nik
Got it to work I just kept trying to move it and it eventually went in.
Szwaboski is offline   Reply With Quote
Old 02-03-2008, 12:45 PM   #22 (permalink)
Szwaboski's Avatar
Nik
here are some photos of it
you can notice my blood on this last one lol
Old 02-03-2008, 12:56 PM   #23 (permalink)
Supreme Pizza!
Izzy's Avatar
It may be hitting that black plastic panel. Try shifting it with your console sticking up like that, see what's going on. The SS adapter is just a piece to make the stalk longer below, so it's going to be a simple mechanical problem.
Old 02-03-2008, 01:28 PM   #24 (permalink)
Litlelev's Avatar
glad you got it to work, did you ever take the blue cap off the short shifter? if so how?
Litlelev is offline   Reply With Quote
Old 02-03-2008, 01:28 PM   #25 (permalink)
Agnt004's Avatar
Greg
Originally Posted by pure2.0 View Post
When I had my Si, I ended up having my short shifter hit the bottom of the black plastic tunnel. The only way I made it work was getting a file and removing some of the plastic until it cleared the bottom of the shifter part.
I had the same problem and used a file as well (you could also use a dremel, it will be faster) to shave down the plastic and make it work. No one sees that plastic anyway, so it doesn't matter if it looks bad, as long as it works, and when it's all done you'll be glad you didn't sell it.
Agnt004 is offline   Reply With Quote
Old 02-03-2008, 01:32 PM   #26 (permalink)
Szwaboski's Avatar
Nik
yea I got the blue cap off the short shifter... I put the shortshifter around a screwdriver with removable heads to change from flathead and philips... I hope you know what i'm talking about... anyways then I stepped on it to keep it steady and used a wrench and rubber hammer and popped it off the same way I did the first time to put on the short shifter. Hope that helps.
Old 02-03-2008, 01:36 PM   #27 (permalink)
Litlelev's Avatar
kinda, but it's not worth the effort/ possible damage to cap just to try out not having the ss on
Old 02-03-2008, 01:37 PM   #28 (permalink)
Szwaboski's Avatar
Nik
yea I know my blue cap will be done for if I take it off again... I'm probably going to go order a new one
Old 02-03-2008, 04:12 PM   #29 (permalink)
I have the same thing, but I can actually get into 2/4/R even though it hits the plastic. I thought maybe that's how it works, the "down" gears are a little shorter than the "up" ones.
peter_x is offline   Reply With Quote
Old 02-03-2008, 05:19 PM   #30 (permalink)
maddhattery's Avatar
kyle
i had that problem wit my corsport to but i just filed it down a lil bit lube it..... if you havent fixed it yet just take a round file and hit it there it is rubbing...
maddhattery is offline   Reply With Quote
Old 02-03-2008, 05:23 PM   #31 (permalink)
thisisdudewhoru's Avatar
brian
I had the same problem and mine wasn't on all the way.
thisisdudewhoru is offline   Reply With Quote
Old 02-04-2008, 08:54 PM   #32 (permalink)
CivicDemon's Avatar
Daniel
I got the Corsport short shifter and install only took me about 20 minutes tops, but i did notice it would not go into 2nd so i had to mess with it a bit by changing in and out of gears and it went in fine just to help it out a bit i got a fiel and i field down the plastick a bit and it feel great.
CivicDemon is offline   Reply With Quote
Old 04-10-2008, 10:39 AM   #33 (permalink)
darkrom's Avatar
Matt
I am having a horrible time getting it into 2nd myself now. Please help me out with some more detail. I don't want to file anything but if someone can show me where to file I guess I will.
darkrom is offline   Reply With Quote
Old 04-10-2008, 11:10 AM   #34 (permalink)
Agnt004's Avatar
Greg
Look at where it hits, and file that spot.
How do you get short shifter OFF? b0yd07 Bolt-Ons And All-Motor 15 01-10-2008 09:30 PM
short shifter john79_99 Mechanical Problems & Technical Chat 0 09-19-2007 06:21 AM
Review: TWM Short Shifter & Cable/Shifter Bushings unplugged Bolt-Ons And All-Motor 11 04-09-2007 12:43 AM
Problem with the Neuspeed short shifter Blk4drSI Bolt-Ons And All-Motor 17 03-30-2007 03:06 AM
Si Short Shifter FigiSi06 CorSport 6 03-10-2006 11:11 PM
