BROCCOLI
![]() Join Date: Dec 2005
NOTHING BUT BROCCOLI
Engine oil, is this too dark?
I have been checking my oil regularly and have been concerned it is too dark.
I went out and took a picture of it on the dipstick. I know that is kinda of crude but what do you all think? Oil meter has recently turned 15%. ![]() This is Amsoil XL 5W-30. I have been considering switching to Mobil1. Seems like Mobil has never had to apologize for it. So I dunno. I am also considering taking a sample and sending it off to Blackstone Laboratory. They have done a lot of tests on Amsoil engine oil, especially for heavy duty Ford trucks and the tests I have seen have always come back very positive. |
#10 (permalink) |
BROCCOLI
I think it is close to 4400.
In my experience the oil life meter counts out very close to 5000 miles. Of course I don't have many total miles but even so, I've monitored when it changes percentage versus mileage when I reset it and again mine looks like it is close to 500 miles per 10 percent. |
#11 (permalink) |
Seems normal if you got 4400miles at 15% oil life.
My oil was a tad bit dirtier but I went without vtecing for long periods of time. Made it to 5500miles at 30% oil life. Oh yea, that oil was the break in oil. Now I'm mobil 1 5W30 Extended Performance + mobil 1 oil filter. I'm going to compare the Regular Syth Mobil 1 oil with Extended Performance. Expect a thread on it. |
#14 (permalink) | |
Funny how people still believe this long time old ancient myth.... DARK OIL DOES NOT MEAN THE OIL IS OLD/BAD! Here...learn something Bob Is The Oil Guy |
#15 (permalink) | |
#16 (permalink) | |
8th Civic Addict
#17 (permalink) |
The bottom line and my point is: You cannot judge oil life by looking at its color. Get an oil analysis done and go from there. OIL COLOR is irrelevant! Look at the dip stick on a DIESEL ENGINE!
Look at this thread... Factory Fill on a Honda Fit. This owner changed the oil at 4800 miles. Blackstone analyzed the used oil and said to run it to 6000 miles. Factory fill, Honda Fit, first oil change, 5k - Bob Is The Oil Guy |
#18 (permalink) | |
Nope, i change my oil at 5000 miles exactly and its never below past 30 %. I had it changed today as a matter of fact. it was at 30 % when i cleared back to 100. |
#19 (permalink) |
If you check the Pennzoil Platinum site, one of the FAQ sheets will tell the same thing that others have posted here. Dark oil is an indicator that the oil is removing combustion by-products and other contaminants. The only real test to see how your oil is performing is to collect a sample for analysis. A $22 Blackstone Labs analysis will also tell you how well your air filter and oil filter are working. They will send you a free sample kit if this is something that you want to pursue.
#20 (permalink) |
BROCCOLI
Yeah, as I mentioned in the OP, I plan on getting this oil tested by blackstone for S' and giggles. I set aside a quart from when I change the oil today.
| Abnormal engine oil levels after changing to synthetic oil?? | Si-aficionado | Mechanical Problems & Technical Chat | 35 | 08-09-2008 08:48 AM |
| Engine Oil question!! | Wilson01 | Do It Yourself Articles | 12 | 08-07-2008 07:14 PM |
| fa1 engine oil change | 1sole | Bolt-Ons And All-Motor | 12 | 12-22-2006 11:36 PM |
| Engine oil, the more you know... | blanz | Do It Yourself Articles | 1 | 12-20-2006 11:20 PM |
| 5w-50 Engine Oil | 1twojay | Mechanical Problems & Technical Chat | 3 | 11-25-2006 11:39 PM |
