Old 02-02-2008, 01:43 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Wiper panel removal
Actually, I need advise on how to remove the crescent shaped plastic panel (with the multiple circular vent holes) located just in front of the wipers. I removed the 3 pop out plastic rivets accessable from the engine bay, but I'm still unable to remove it. I'm sure there are more somewhere I don't know about.
Turbotezza is offline   Reply With Quote
Old 02-02-2008, 01:53 AM   #2 (permalink)
Ur soul. I haz it.
jasonandre's Avatar
Disciple of Discord
I think there's at least five more clips on the opposite side of that crescent-shaped plastic panel that you have to remove. At least, that's what it shows in the service manual.
Originally Posted by Special Ringpop View Post
Your ass isn't typically a reliable source.
Hey, people get on my case for being a Godless Atheist Butt-Pirate, but I try to be objective.
jasonandre is offline   Reply With Quote
Old 02-02-2008, 11:14 AM   #3 (permalink)
Are those in the engine bay too?
Old 02-02-2008, 11:23 AM   #4 (permalink)
fap n nap™
ryryninja's Avatar
205whp 147tq :D
There are 5 clips in total. Three of them have shorter clips than the standard engine bay clips. The last two clips are the engine bay clips in the corner of the top part of the molding. After those clips are out you should be able to pull that plastic cover out and have access to the metal part of the cowl
|108K Miles|I beat my tires harder than i beat my meat
ryryninja is online now   Reply With Quote
Old 02-02-2008, 11:37 AM   #5 (permalink)
chenslee_cheese's Avatar
Performance>Aesthetics
Watchout, the ends of that piece have tabs that hook under the corner pieces. I broke both of mine off during the header install.
chenslee_cheese is offline   Reply With Quote
Old 02-02-2008, 11:43 AM   #6 (permalink)
NcSi's Avatar
Bryan
its called a cowl, go to autozone, pepboys ect and get a clip removing tool it makes it 10 times easier.....when u have the five clips out pull down on the center and up on the sides of the cowl..comes off easier without breaking anything........also u are goin to need to remove ur wipers to if ur taking everything off :) its either a 17 or 19 cant remember
NcSi is offline   Reply With Quote
Old 02-02-2008, 12:44 PM   #7 (permalink)
Thanks guys.
Check this sheit out!
5ZIGEN INTERNATIONAL INC.
Old 02-02-2008, 01:12 PM   #8 (permalink)
fap n nap™
ryryninja's Avatar
205whp 147tq :D
That looks pretty good too bad its covered
Old 02-02-2008, 01:22 PM   #9 (permalink)
Tugzy's Avatar
1) Remove the Wiper Arms
2) Remove 3 Clips that hold the cowl top
3) Pull up on the cowl top to unset the clips
4) Pull up on the cowl top from the side covers
installation is reverse
Tugzy is offline   Reply With Quote
Old 02-04-2008, 10:01 PM   #10 (permalink)
you dont need to remove the wiper arms,just turn them on and when they are facing straight up shut off the key
hondaguy848 is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/76800-wiper-panel-removal.html
8th Generation Honda Civic Forum This thread Refback 02-02-2008 02:09 PM
Wiper removal, insert replacement Sedan thedamaja Do It Yourself Articles 17 11-09-2008 12:05 PM
Different wiper styles. Why? civcracker Civic Coupe And Sedan 2 01-20-2008 10:55 PM
Wiper Blade Removal eddiel Mechanical Problems & Technical Chat 2 10-06-2007 06:00 PM
wiper warblade Civic Coupe And Sedan 5 06-08-2006 10:17 PM
Mechanics-wiper arm removal/adjustment civicdoody Mechanical Problems & Technical Chat 1 04-13-2006 02:02 AM
