Old 01-31-2008, 05:53 PM   #1 (permalink)
Help on scangauge2
Scangauge keeps saying connecting..vsa and vsa light turns on. CEL light came on after forcing auto code. Any help?
yoyosupmang is offline   Reply With Quote
Old 01-31-2008, 05:56 PM   #2 (permalink)
rickhilbert's Avatar
Strange....are you connecting with the car off???
rickhilbert is offline   Reply With Quote
Old 01-31-2008, 06:11 PM   #3 (permalink)
i turned the car on. The VSA light came on and so did the vsa triangle..then the CEL came on. The temp goes up and down every 10 seconds. It keeps saying connecting and then goes blank then i press the red button and it says connecting again. Is my 2007 civic si coupe an obd2?
Old 01-31-2008, 06:33 PM   #4 (permalink)
c130turboprop's Avatar
yea its an OBDII(honda calls is dlp or something like that). i have an 07 si sedan and it works fine. only thing i could say is disconnect it and reconnect it. even try it in another car and see what happens and then try it in your car again...
c130turboprop is offline   Reply With Quote
Old 01-31-2008, 06:42 PM   #5 (permalink)
how long did it take you to connect? mines keep saying connecting then the screen goes blank
Old 01-31-2008, 07:01 PM   #6 (permalink)
anybody help?
Old 01-31-2008, 07:18 PM   #7 (permalink)
any scangauge users with problems?
Old 01-31-2008, 07:55 PM   #8 (permalink)
mine took like 15 seconds to connect. after it connects the first time it doesnt have to connect anymore, it should come on when the car is turned on. which reminds me, if you plug it in with the car off, it will connect and shut off, the only way to keep it on is to have the car running... so have you had the car on and does it still do the same thing???
Old 01-31-2008, 08:14 PM   #9 (permalink)
i had the engine running when i turned it on. It still says connecting for a real long time. Im just going to contact support and have them help. I heard they have good customer service so we will see. Some guy on mustang forum had the same thing and it was a defective wire. Just a question, anybody with an 07 si coupe have the scangauge and it works?
Old 01-31-2008, 08:19 PM   #10 (permalink)
ya, i would call their support. if its not working with the car running, then there is something wrong with the gauge itself or like you said, the wire. good luck.....
Old 02-17-2008, 10:23 PM   #11 (permalink)
Excalibur's Avatar
Jeremy
In for results. I just got mine. I haven't played with it yet. I will later though.
Excalibur is online now   Reply With Quote
