Old 01-30-2008, 08:24 PM   #1 (permalink)
Install HFP LIP at 60 degrees or higher?
On collegehillshonda, their website/tutorial of the hfp lip states that you must install the hfp lip in an area that is at 60 degrees or above. Has anyone installed the lip in colder temperatures? If so, how did it go?
sinafl is offline   Reply With Quote
Old 01-30-2008, 11:49 PM   #2 (permalink)
anyone?
Old 01-30-2008, 11:58 PM   #3 (permalink)
hoanger's Avatar
Jason
I believe the only reason is because of the double sided tape that you need to attach to the body.
I actually just recently took my lip off today and it came off fairly easy.. right now it's -40C which is cold as hell.
You should wait, if it's too cold.. the tape may not stick properly and eventually just slowly peel off.
hoanger is offline   Reply With Quote
Old 01-31-2008, 12:00 AM   #4 (permalink)
Would a heat gun work for putting the tape on lol?
Old 01-31-2008, 12:09 AM   #5 (permalink)
Szwaboski's Avatar
Nik
maybe put it on in your garage if you have a 2 car garage... just get some space heaters?
Szwaboski is offline   Reply With Quote
Old 01-31-2008, 12:12 AM   #6 (permalink)
Szwaboski's Avatar
Nik
Damn -40C is like -40F
Old 01-31-2008, 12:14 AM   #7 (permalink)
hoanger's Avatar
Jason
a heat gun WOULD work, but you don't wanna sit there for like a half an hour - an hour for the tape to secure itself. The heat gun is pretty hot itself, so you gotta watch not to burn the clear or anything.
You should wait until it warms up a bit.. better to be safe than sorry.
Unless of course you've got a garage, set up some heaters like Szwaboski suggested.
Old 01-31-2008, 12:16 AM   #8 (permalink)
hoanger's Avatar
Jason
yeah it's friggin insane.
we've had a windchill warning for the past three days, it was the last day today.
On monday it was -45C with the windchill, and at one point -49.
Old 01-31-2008, 12:18 AM   #9 (permalink)
klk15's Avatar
Kerry
lmao actually -45C is like close to -80F cuz 0C=32F
klk15 is offline   Reply With Quote
Old 01-31-2008, 12:21 AM   #10 (permalink)
SamsFG2's Avatar
I did mine a month ago in my garage. Mightve been like 40 degrees outside. After I was done and went out to drive it started raining. But since then the lip is holding fine.
SamsFG2 is offline   Reply With Quote
Old 01-31-2008, 12:25 AM   #11 (permalink)
hoanger's Avatar
Jason
-45 degree Celsius = -49 degree Fahrenheit
according to onlineconversion.com
I was confused about that too.. but as the temperature decreases in Celcius, it starts to even out with Fahrenheit... dunno why
Old 01-31-2008, 08:44 AM   #12 (permalink)
Szwaboski's Avatar
Nik
because Celsius was based on the 0-100 scale so it weirds out going negative and past 100
Old 01-31-2008, 08:53 AM   #13 (permalink)
Excalibur's Avatar
Jeremy
We did the front and the back on our own in cold weather, but used a heatgun and had no problem.
Then I took it to the dealership for the sideskirts and I don't know if they used a heatgun or not, but it has spots that didn't stick all that great. I would follow what honda says if I could do it over again.
Excalibur is online now   Reply With Quote
Old 01-31-2008, 10:15 AM   #14 (permalink)
Im just trying to do the front
Old 01-31-2008, 10:17 AM   #15 (permalink)
Jepetto's Avatar
Did mine in the garage few weeks ago. Used a hair dryer to warm the tape. No problems so far.
Jepetto is offline   Reply With Quote
Old 01-31-2008, 12:36 PM   #16 (permalink)
alright sweet.. ill give it a go.
HFP Front lip install help... Englishe30 Mechanical Problems & Technical Chat 11 08-20-2007 05:20 PM
HFP Lip Kit Install Questions Vi3t DrAgOn 714 Inside and Out 18 07-03-2007 04:44 PM
HFP Lip kit install...bolts needed?!?! xlur8ed Inside and Out 3 05-23-2007 01:33 PM
HFP lip kit and OEM fog install price? mattSi Inside and Out 9 03-04-2007 04:04 PM
HFP lip kit and OEM fog install price? mattSi Inside and Out 3 02-20-2007 08:47 PM
