Old 01-29-2008, 08:46 PM   #1 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
Vehicle Speed Sensor - WHERE!?
Im trying to install my Avic-D3 and i need to tap into the VSS. I found a post that said it was a blue/white wire located in a brown 20 pin connector located under the passenger side dash.
Ive been looking and i cannot for the life of me find this wire.
Im also going to need to know where the reverse wire is.... unless i manage to find it while i go and wait for a response on here.
HELP!!!!
"A car never breaks. It presents us with opportunities to upgrade."
Phalanx is online now
Old 01-30-2008, 01:06 AM   #2 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
Old 01-30-2008, 09:04 AM   #3 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
morning bump?
car is sitting in my garage in pieces
Old 01-30-2008, 09:15 AM   #4 (permalink)
NIGHTHAWKSI's Avatar
Ian
try the blue wire in the harness at the back of the radio. if there is more than one blue wire...i dont know about which one it is. (got this from the12volt.com) if there is more than one, you could try process of elimination to make sure your not tapping into a speaker,power ground,illumination,or any other wires.
it makes sense that there is a wire going to the back of the radio since the OEM radio has a VSS funstion to amplify teh music the faster you go.
NIGHTHAWKSI is offline
Old 01-30-2008, 09:22 AM   #5 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
Thats exactly what I was thinking... but by the time i got my dash off my mind was so shot i didnt think of that. I missed the step in the DIYs where you have to take out the 2 screws below the HU where that little bin is in front of the shifter. So I spent like 2hrs prying and pulling and also managed to gash up my dash a bit.
... It hasnt been fun. I just wish I was at home and not work... so i could sit and get this done.
I'll try the blue wires tonight... assuming no one posts here w/ an exact answer
Old 01-30-2008, 09:28 AM   #6 (permalink)
Ian
so far...i think that is the exact answer. the12volt has a wiring list for any wires needed for a radio or alarm install. unless some one has a wiring/pinout diagram....
EDIT: the more i research it, it should be a darker blue wire.
Old 01-30-2008, 09:40 AM   #7 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
Hmm. Alright. Ill have to check it out when i go home. Im lookin around and the12volt isnt much help to me, lol. Electrical wiring isnt my thing.
Old 01-30-2008, 11:20 AM   #8 (permalink)
MaXaZoR's Avatar
The VSS is behind the dash, I'll try and remember what color it is
MaXaZoR is offline
Old 01-30-2008, 11:33 AM   #9 (permalink)
MaXaZoR's Avatar
I'm almost positive it is the blue/silver wire in one of the connectors in the back of the radio. The wire your thinking about in the drivers side kick panel is the for the parking brake.
MaXaZoR is offline
Old 01-30-2008, 11:40 AM   #10 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
Ill try the blue/silver wire. Hopefully theres only one. I found the parking brake one, but im going to dot he bypass anyways. Hopefully the bypass wont mess w/ the bluetooth add-on since the mute wire gets grounded.
Old 01-30-2008, 06:13 PM   #11 (permalink)
MaXaZoR's Avatar
If you still have trouble tonight getting it to work, send me a PM and I'll double check which wire I'm using tom morning.
~Josh
MaXaZoR is offline
Old 02-19-2008, 02:39 PM   #12 (permalink)
So which wire was it?
noran01 is offline
Old 02-19-2008, 03:08 PM   #13 (permalink)
Dont get eaten!!
Phalanx's Avatar
Ski-Free Monster
Blue wire w/ silver stripe on the 17-pin connector that went into the back of the stock Head unit
Old 02-19-2008, 03:57 PM   #14 (permalink)
volvo9's Avatar
Andrew
I took a picture of it on the radio harness when I was removing my Z2. It's the center blue wire in the first pic, I should have highlighted it.
VSS and factory amp turn on
volvo9 is offline
Old 02-19-2008, 09:03 PM   #15 (permalink)
Thanks!!!
noran01 is offline
Old 02-19-2008, 09:08 PM   #16 (permalink)
illusionstwice's Avatar
The original --> "J" <--
good luck. im way to scared to do shit like this on my own.
illusionstwice is offline
Old 03-01-2008, 07:32 PM   #17 (permalink)
Just to confirm, it's the SPD wire from this write up, right?
DIY: Aftermarket radio Install in an EX
emerylu is offline
2007 CIVIC DX Speed sensor wire? akshay9000 I.C.E., Electrical, Security, & Navigation 7 07-31-2007 09:30 PM
Where is the Vehicle Speed Sensor on the Hybrid? swspeedometer Civic Hybrid 1 05-15-2007 11:54 PM
Hybrid w/ nav need speed sensor wire anh4u2nv I.C.E., Electrical, Security, & Navigation 0 04-08-2007 01:02 PM
VSS Speed Sensor on 06 Civic EX ahackney I.C.E., Electrical, Security, & Navigation 3 09-04-2006 09:21 AM
what is the best place for tilt sensor and motion sensor? a13x Garage 0 01-23-2006 11:01 AM
