ur car pulling to the right slowly and eventually is normal. the roads u drive on are built at an angle so that the water from the rain goes off to the right side of the road and not leaving puddles. thus, ur car, even though it's perfectly aligned, will pull to the right.
and as far as second gear, when u shift, don't force it in, but be firm at the same time and it'll go in. |
| alignment problem, pulling to the right | 07k20z3ftw | Mechanical Problems & Technical Chat | 7 | 01-27-2008 10:21 PM |
| First gear problem on 07 SI | trystar | Civic SI | 18 | 11-12-2007 03:15 PM |
| help!! problem with 2nd gear | Hi-ReV | Mechanical Problems & Technical Chat | 3 | 10-22-2007 09:03 AM |
| Pulling and Drifting? Alignment TSB. READ IF YOU HAVE THIS PROBLEM! | 07k20z3ftw | Mechanical Problems & Technical Chat | 1 | 07-22-2007 07:07 PM |
| 1st gear problem | Ratchet | Mechanical Problems & Technical Chat | 13 | 04-12-2007 05:39 PM |
