#64 (permalink) |
87, it'll knock, and the timing will be retarded (not to be mistakened with the "idiot" retard, but timing set back), and then you'll lose power, and then everything "will be fine"
Just putting in 87 once is not going to do anything to your engine. Drive it normally (not spirited/vtec) and it wont even have to retard timing. I can say all of this out of experience. I did a test, was putting in 87 octane for 3 months. Only noticable difference was loss of power after my first time knocking (hard acceleration in high heat environment). Sort of felt like AC was on, without it actually being on. when i put 93 in again, i didnt feel any noticable difference until after about 2 1/2 tanks when i believe the timing was back to normal again. |
#65 (permalink) |
A little pinging isn't that bad. My Dad had a truck for 20 years that didn't ping with 91 octane yet he always filled it with regular 87. It would always ping under load yet the truck lasted a long time with no problems.
If you can't hear it pinging then don't worry about it. The car automatically adjusts it's timing anyway when lower octane gas is used. |
#66 (permalink) | |
And the knock sensor doesn't really control anything it will just "hear" detonation and this will tell the ECU to retard ignition advance and add fuel. And when it's cold outside the cooler air will cause detonation even more because of the higher concentration of oxygen in the air which will burn all that much faster and better and there will NOT be enought ignition retard available to stop this. So if you want to play with fire to save a few pennies then go for it. I can understand if you have no choice but don't use more than a few gallons. Just use enough to get you somewhere that will have the proper octane fuel. Or go get some octane booster. Even though that stuff is pretty much a joke. But it will help enough to keep your motor in one piece. |
#67 (permalink) |
^^ he's correct. This car requires 91+ octane through compression alone. Timing is another thing they tweak to require higher or lower octane ratings (thus boosting power) But you can't really tweak this as much at 11:1. But there are 10:1 and stuff inbetween 10:1 and 11:1 that requires 91+ octane because the timing is advanced pretty far from the factory.
Don't put 87 octane in your car ever. If you have to, drive it like a baby, and don't put a full tank ever. Fill it up with small amounts like 1-2 gallons. |
#73 (permalink) |
Ok, so yes I will do a search here, but now we're on the subject..
Which octane booster? Are any octane boosters safe or to be avoided? Booster dangerous for the Si engine in particular? Thank goodness I hope this would be a very very temporary thing. Worst case 1 tank-full. |
#75 (permalink) | |
just read the bottle and see which one is the strongest. I dont think there are any ones that arnt safe or that we should avoid. they all should be safe. |
#78 (permalink) |
mmm i use 91...i dont think there are any 93 octane in the LA area. LOL to whoever said they drive their GSR and Si the same...what point does that make? two complete different cars with 2 complete different compresion ratios. What you said dont make sense. For your own protection, i hope you start putting in the proper type of fuel your car needs, no one on here wants you to learn it the hard way.
#80 (permalink) |
I would say, if you have to use low octane, then don't use full throttle, especially at low revs... except at high altitudes where it might be ok.
Another issue would be the variation of actual octane - if the variation is such that the 87 actually turns out to be 85, then expect problems... |
| What grade of gas? All gas questions answered! **Merged all gas threads** | clm10k | Civic SI | 888 | 10-01-2008 04:36 PM |
| 87 octane gas mistake | dwm5f5 | Mechanical Problems & Technical Chat | 65 | 09-24-2008 02:09 PM |
| do you use 91 or 89 or 87 Octane gas for your si? | igotmysi | Civic SI | 7 | 12-20-2007 06:55 PM |
| What is the worse that can happen using 87 instead of 9x octane gas? | tite681 | Dealership Experience | 4 | 09-04-2007 09:51 AM |
| 87 octane or 91 octane??? | kene79 | Civic SI | 18 | 07-31-2007 06:00 AM |
