Old 01-30-2008, 01:59 PM   #21 (permalink)
achilles225's Avatar
Roger Crockett
Originally Posted by xvoltm2 View Post
was she hot?
you still never answered the question
achilles225 is offline   Reply With Quote
Old 01-30-2008, 02:02 PM   #22 (permalink)
Snake-eyes's Avatar
Shake & Bake!!!!
Originally Posted by MBK View Post
^^^you just put it in your gas tank? how much does that cost?
Sea foam can also be added to your oil.. techron concentrate is fuel only...the stuff isnt that expensive considering what it does...around 13 bucks .
They recommend using techron concentrate every 3,000 miles. Carbon build up is nasty @.@... BTW these are oil base products...
Techron in the gas station is simular but not as concentrated as the "real stuff"
Thats why I tell people if you want to take care of your car fill it with "good" gas. Its worth the extra money to keep your car running better and longer!
Snake-eyes is offline   Reply With Quote
Old 01-30-2008, 02:05 PM   #23 (permalink)
soxfan's Avatar
David
somewhat related issue: any risk in using octane boosters? I used a product from Lucas a couple months a go and it seemed to make the engine accelerate harder
soxfan is offline   Reply With Quote
Old 01-30-2008, 02:08 PM   #24 (permalink)
Snake-eyes's Avatar
Shake & Bake!!!!
your imagination....Octane boosters do nothing..
Only time higher octane = more hp is when you have a fuel map to run that higher octane in your ECU.
Old 01-30-2008, 04:21 PM   #25 (permalink)
jumboshrimp23's Avatar
Keith
Originally Posted by ImBiginKorea View Post
Its about 2 dollar difference for me.
Hmm 2 dollars more and 197hp or save 2 dollars and have 140hp. Decisions, decisions.
--Korea
The Si is well worth it if u can afford it
jumboshrimp23 is offline   Reply With Quote
Old 01-30-2008, 05:48 PM   #26 (permalink)
KraziAzn's Avatar
David
still waiting...
was she hawt?
KraziAzn is offline   Reply With Quote
Old 01-30-2008, 05:52 PM   #27 (permalink)
ViperSam's Avatar
NOVICE Crew
ViperSam is offline   Reply With Quote
Old 01-30-2008, 09:09 PM   #28 (permalink)
isunelan's Avatar
if it does not matter and once you put in 91 ull be fine then why dont you just pump 89 and a year later pump the 91?
isunelan is offline   Reply With Quote
Old 01-30-2008, 09:54 PM   #29 (permalink)
Jason
just go put some chevron or texaco gas in ur car. they put techron into their gasolines.
Old 01-30-2008, 10:34 PM   #30 (permalink)
Snake-eyes's Avatar
Shake & Bake!!!!
they put a small amount in thier gasoline and it will not get rid of carbon buildup that already exsists from previous damage. You should always be running these brands inorder to prevent build up in the first place
Old 01-31-2008, 02:05 AM   #31 (permalink)
EchoHawk7's Avatar
Jeff
Its not expensive, only a few bucks for a bottle of the stuff at most.
I use the stuff every once in a while. Gives me the warm fuzzies that im taking care of my engine.
EchoHawk7 is offline   Reply With Quote
Old 09-22-2008, 05:34 PM   #32 (permalink)
4door's Avatar
terry
87 oct in si
my girl just called me and all the gas stations are out of 93 and 89..... now whats the down fall of putting 87 in? i told her just to put a gallon in but i have to get around and i might have to full up with the 87 oct...
4door is offline   Reply With Quote
Old 09-22-2008, 05:35 PM   #33 (permalink)
PhantomSi's Avatar
Cobb
Dont....
PhantomSi is offline   Reply With Quote
Old 09-22-2008, 05:36 PM   #34 (permalink)
#1 Post Whore
07mugencivic's Avatar
ToE kNeE
what happened to all the gas
Originally Posted by 0720Steve View Post
we should rename : beer: to :tony:
Old 09-22-2008, 05:37 PM   #35 (permalink)
huanqi's Avatar
Huan
91 atleast...or just walk or call cab..LOL
huanqi is offline   Reply With Quote
Old 09-22-2008, 05:41 PM   #36 (permalink)
GO Ravens!!!
charger2's Avatar
Ryan - Keeper of Secret Spot
That's really strange. Around here 87 is ALWAYS the first thing to run out, never had any problem getting 93 octane though.
I would strongly advise against using anything below 91 octane.
*** 8thcivic.com Member #32327 ***
charger2 is offline   Reply With Quote
Old 09-22-2008, 05:41 PM   #37 (permalink)
szuberi's Avatar
SAL
high compression remember....11:1
szuberi is offline   Reply With Quote
Old 09-22-2008, 05:54 PM   #38 (permalink)
Chadillac's Avatar
Your engine does have a knock sensor that will adjust timing if you put in a lower octane gas. You engine will probably lose some power due to the timing, but I highly doubt you'll damage your engine by filling it up with 87 a few times. Just listen for engine knock, if you don't hear it, your engine will be fine.
Chadillac is offline   Reply With Quote
Old 09-22-2008, 05:57 PM   #39 (permalink)
innrfusion's Avatar
Fuentes
dont try any hard acceleration either ull be ok
innrfusion is offline   Reply With Quote
Old 09-22-2008, 06:01 PM   #40 (permalink)
asdf's Avatar
its fine, just dont put a heavy load on it.
asdf is offline   Reply With Quote
What grade of gas? All gas questions answered! **Merged all gas threads** clm10k Civic SI 888 10-01-2008 04:36 PM
87 octane gas mistake dwm5f5 Mechanical Problems & Technical Chat 65 09-24-2008 02:09 PM
do you use 91 or 89 or 87 Octane gas for your si? igotmysi Civic SI 7 12-20-2007 06:55 PM
What is the worse that can happen using 87 instead of 9x octane gas? tite681 Dealership Experience 4 09-04-2007 09:51 AM
87 octane or 91 octane??? kene79 Civic SI 18 07-31-2007 06:00 AM
