Old 01-27-2008, 02:06 PM   #1 (permalink)
mito's Avatar
High rev Non-stop engine - how long would it last?
NEWBIE QUESTION:
Out of curiosity, how long an engine would last if you had it at max rev non-stop?
does the engine explode or something?
note: consider that the engine is properly cooled and the fuel tank is always full.
mito is offline   Reply With Quote
Old 01-27-2008, 02:08 PM   #2 (permalink)
silverspoon1996's Avatar
JJ
its going to overheat and when the metal starts to break down the oil is pretty much sludge.
silverspoon1996 is offline   Reply With Quote
Old 01-27-2008, 03:01 PM   #3 (permalink)
The Sticker Man
blue rocket's Avatar
GrafiXpressions.com
i always thought they ran the engines at redline for a few hours or something while they are still in the factory.
blue rocket is offline   Reply With Quote
Old 01-27-2008, 03:11 PM   #4 (permalink)
tite681's Avatar
USDaMn
Yeah, I heard the same thing but I have a hard time believing it.
tite681 is online now   Reply With Quote
Old 01-27-2008, 03:16 PM   #5 (permalink)
JJ
RX-7 9000RPM Sustained ( Brando pop )
Thats a motor at 9k on its last legs.. they murdered it..
Old 01-27-2008, 03:22 PM   #6 (permalink)
Slowroll90's Avatar
Aaron
many diesel engines are designed to run 100% power out put when they run
this isnt very fast but they do it a lot
anyhow
car engines arent designed to handle that
race car engines dont last very long i dont believe
i remember watching espn about top fuel draggsters
anyway the mechanic said that there are certain parts replaced every race
and the engine itself as a whole is only expected to last about 5 or 6 races
thats one weekend or so i think
Slowroll90 is offline   Reply With Quote
Old 01-27-2008, 03:26 PM   #7 (permalink)
Tugzy's Avatar
Did you watch the Rolex 24 hour series this weekend? Nuf said....
Tugzy is offline   Reply With Quote
Old 01-27-2008, 03:32 PM   #8 (permalink)
mito's Avatar
incredible.
questions: it's much worse to hit redline while idling than on full speed? (on the road, going up the hill, etc.)
at the end of the video they can't start the engine. did it melt? what could have happened to it (technical side)...
Old 01-27-2008, 03:33 PM   #9 (permalink)
JJ
enough said what??? That cars last or dont.. Like 75% that start dont get half way though... you cant beat the snot our of something for a long time and expect it to last.. I mean go as far as F1 or Nascar.. theres cars race after race after race that DNF... and those are hand built to spec.. for maximum performance.. Nothing is meant to be running at full power output for an extended period of time.. Energy produces heat.. and heat will break down the engines parts and fluids...
Old 01-27-2008, 03:35 PM   #10 (permalink)
JJ
when your idling the car has nothign passign through the radiator... cooling the fluid... so yes its probally worse idling then going up hill as long as the hill isnt a rediculous incline..
and the killed the seals in the motor.. no compression.. no start.. hahaha..
Old 01-27-2008, 03:36 PM   #11 (permalink)
Slowroll90's Avatar
Aaron
[quote=mito;2127857]incredible.
there is no load on it
Old 01-27-2008, 03:40 PM   #12 (permalink)
da_lsvtak's Avatar
^^^ this is very true. take in consideration im going a little bit out there, but i work on F-16s and im a crew chief on one. after every flight we have to take a JOAP sample which is a bottle filled with the engine oil, they take it to a shop and burn it to see how much metal break down is occuring in the motor itself. and those engines are usually run at more than 100% power in afterburner.
now take that principal to cars and what you get is friction. and i mean ALOT of friction. factory gas engines arent designed to be ran at redline for every gear on every shift. your motor would eventually decay itself to the point it collapses, hense why you see alot of dropped valves and snapped connecting rods on cars that are constantly raped.
da_lsvtak is offline   Reply With Quote
Old 01-27-2008, 03:46 PM   #13 (permalink)
JJ
Most endurance engines are mildly tuned.. they balence them and use thermal coatings and other coatings to reduce friction, all this is to try to make the engine last longer... it helps but no matter what it is you push to its limits for a long time its going to break down and stop..
Old 01-27-2008, 06:05 PM   #14 (permalink)
Asif22's Avatar
Mohamed El-Mubaslat
Wow I would have taken it to a track or through the woods or something and beat the piss out of the motor like driving it...try some clutchless shifting or go from like 5th to 1st, now that would be fun!
Asif22 is offline   Reply With Quote
Old 01-27-2008, 06:17 PM   #15 (permalink)
mito's Avatar
and they killed the seals in the motor.. no compression.. no start.. hahaha..
from the video I could see that they stopped the engine (it was still working at 9k rpm) and turned it off. The engine wouldn't start afterwards. So if the seals were killed, shouldn't it have stopped before during redline?
Old 01-27-2008, 06:27 PM   #16 (permalink)
datbacker59's Avatar
Its a Live2Hustle Thang...
hope no one is "smart" enough to try on there civic
datbacker59 is offline   Reply With Quote
Old 01-27-2008, 06:41 PM   #17 (permalink)
TommyD's Avatar
A Honda engineer/tech once leaked that any new engines are tested before going into a production model by running at redline for 24 hours. This was on the motorcycle side, no idea on the automotive side, but wouldn't think it would be much different. And by that he didn't mean the motor in your bike, he was referring to testing newly designed engines for reliability.
TommyD is offline   Reply With Quote
Old 01-27-2008, 06:57 PM   #18 (permalink)
mito's Avatar
imagine the noise level and pollution...
Old 01-28-2008, 01:49 AM   #19 (permalink)
Slowroll90's Avatar
Aaron
honda sportbikes have a rep for being about to take a beating and keep going
Old 01-28-2008, 09:30 AM   #20 (permalink)
NIGHTHAWKSI's Avatar
Ian
whatever you do...dont do it for 4 years...
Cruising at 7500 RPM for 4 years: How to throw a rod.
NIGHTHAWKSI is online now   Reply With Quote
Engine idles high for too long in morning andreewlee Civic SI 23 11-29-2007 06:26 PM
Random tech High flow cat VS AJP high flow cat fairladyz_gt-r Bolt-Ons And All-Motor 8 05-11-2007 06:08 PM
stop to go Ratchet Mechanical Problems & Technical Chat 9 04-10-2007 01:11 PM
Vibrant header/high flow combo vs. Comptech/RT high flow carter21 Bolt-Ons And All-Motor 9 02-08-2007 01:35 PM
Honda Develops Advanced VTEC Engine Combining High Power and Environmental Performance webby Honda Industry News 0 10-27-2006 03:45 AM
