Second Gear Problem
Hey first off i have an 07 Civic Si. I have been having a problem when shifting from first to second gear at high rpms. The gears will grind horribly sometimes. Im not sure why. Its only when going into second gear. It seems like it started once i put my Comptech Short Shifter on, but im not blaming it on that. Just wondering if anyone else has problems? Should i take the car in for a check up. I have an extended warranty so im fine there. And yes my foot will be all the way down on the clutch and still grind.
#7 (permalink) | |
![]() Remove the short shifter, put it back to stock....the short shifter increases the speed of your shifts. The transmission synchros cannot keep up with the quick shifting. |
Yup happens to me to!! I hate that, and honestly slow shifting? Before i would grind the gear which sounded horrible, but now it seems more like i miss the gear. I knew it wasn't just me, so when i heard other peeps were having the same problem i felt a bit more confident.
| First gear problem on 07 SI | trystar | Civic SI | 18 | 11-12-2007 03:15 PM |
| help!! problem with 2nd gear | Hi-ReV | Mechanical Problems & Technical Chat | 3 | 10-22-2007 09:03 AM |
| First gear problem now... | Omes | Mechanical Problems & Technical Chat | 1 | 03-07-2007 02:33 AM |
| 2nd gear problem | 06civSi | Mechanical Problems & Technical Chat | 10 | 01-26-2007 02:16 PM |
| Problem with 3rd Gear? | imtim25 | Mechanical Problems & Technical Chat | 57 | 08-23-2006 09:28 PM |
