Old 01-27-2008, 09:43 AM   #1 (permalink)
Question about turning on the car (SI)
When you guys turn on the car, obviously you first floor the clutch then turn it on. After that do you just dump it or let it off slowly. I usually dump the clutch when turning the car on but i felt some sort of vibration today when i was dumping it slowly.
I also did the 3rd gear test and the car was able to move with the clutch in friction point.
Wierdochild89 is offline   Reply With Quote
Old 01-27-2008, 10:30 AM   #2 (permalink)
When i turn off my car i always leave it in gear because if you dont there is nothing holding it in place other then e-brake. You can still manually push your car w/ just e-brake so thats not good. But neways, my answer is no i dont dump the clutch unless im warming the engine up first then ill pull gear into neutral and lightly let out clutch
bmnorm2 is offline   Reply With Quote
Be careful:turning 18 yoyosupmang Garage 30 12-14-2007 12:19 PM
So i'm turning 18..I need some Ideas.. Skyline4life Water Cooler 42 07-13-2007 10:12 PM
Turning off car w/ Subs brooklynscat69 I.C.E., Electrical, Security, & Navigation 23 03-06-2007 10:03 AM
Turning off car after speeding zelmac Mechanical Problems & Technical Chat 20 02-19-2007 04:14 AM
braking when turning Mateen Civic Coupe And Sedan 6 01-02-2007 08:37 PM
