#1 (permalink)
The new TSB from Honda to repair the neg. camber of the rear end is:
TSB 08-001 The very first one of the year. About friggin time!! Old Dog New TSB for Rear Camber Problem: 08-001 (merged) pdf file Last edited by webby; 01-29-2008 at 04:54 PM. |
Just talked to Honda: If your vehicle is exhibiting excessive tire wear on the inner part of the tire or cross directional wear (causing vibration), then you are entitled to new tires, and some camber alignment repair for the rear upper control arms and some other bits.
So if your tires are wearing away VERY quickly like mine did, bring them in and you should be able to get Honda to fix it for you. I'll be bringing my old tires to get the rear camber aligned. |
| Camber Problem | furrowjj | Mechanical Problems & Technical Chat | 38 | 03-18-2008 01:17 AM |
| A TSB Story (good one) | kero | Mechanical Problems & Technical Chat | 8 | 08-24-2007 12:41 PM |
| DIY (sort of) SPC Camber Bolts Install | HondaScott | Suspension and Brakes | 9 | 08-09-2007 11:20 AM |
| HELP!!! Camber problem with Si suspension on LX | aircuellar | Suspension and Brakes | 10 | 09-25-2006 10:41 AM |
