Old 01-22-2008, 02:59 PM   #1 (permalink)
immortalsoul's Avatar
Cause of knocking sound?
well my engine at idle has a huge knocking sound... wondering what could have caused this... its a r18 and here are the mods
Injen CAI
Apex'i N1 muffler
and things i recently took off
Apex'i VAFC II
Greddy e-manage ultimate...
immortalsoul is offline   Reply With Quote
Old 01-22-2008, 05:45 PM   #2 (permalink)
at what rpms is your car idling at? if its under ~700 you might need to reset your ecu so that it can relearn its idle settings with your change in equipment
Young Gunna is offline   Reply With Quote
Old 01-22-2008, 06:08 PM   #3 (permalink)
BigT's Avatar
Injen CAI
Apex'i N1 muffler
Apex'i VAFC II
Does the noise only happen at idle? Is it an internal engine knock?
BigT is offline   Reply With Quote
Old 01-22-2008, 08:09 PM   #4 (permalink)
internal knock and idle onlyyyyyyy idle stays above 700rpm
could it be that the ecu is just trying to relearn itself after taking off the piggybacks?
Old 01-22-2008, 08:18 PM   #5 (permalink)
BigT's Avatar
Hmm. The only way I can think of that the ECU could cause an engine knock would be if it was advancing the timing too far and causing detonation. If this happened the knock sensor should simply correct for it.
Did the noise start right after you removed the mods? What circuits/sensors were the piggybacks connected to? Has anything else changed recently?
Old 01-23-2008, 12:21 AM   #6 (permalink)
happened after took of the piggybacks. both piggy backs were directly installed on the ecu's circuit i think..? not to sure if this is the case then it should fix itself?
Old 01-23-2008, 12:23 AM   #7 (permalink)
KraziAzn's Avatar
David
yah im getting the same knocking sound
i got
AEM CAI
Greddy Ti-C
how do i reset the ecu?
KraziAzn is offline   Reply With Quote
Old 01-23-2008, 09:07 AM   #8 (permalink)
Resetting your ECU: After mods and Environment changes. - Honda Acura Forum
computer help, need help getting sound clips hondasi006 Water Cooler 4 08-05-2007 02:09 AM
premium sound head unit vs regular head unit be0524 I.C.E., Electrical, Security, & Navigation 28 07-23-2007 05:26 PM
back pressure (popping sound) hondasi006 Mechanical Problems & Technical Chat 11 04-22-2007 12:01 PM
civic ex cp engine knocking sound on idle oplok72 Civic Coupe And Sedan 35 05-03-2006 11:00 AM
Sound Quality in the 06 civic hamm I.C.E., Electrical, Security, & Navigation 9 12-30-2005 09:41 AM
