Old 01-21-2008, 06:02 PM   #1 (permalink)
Open moonroof rattle + A pillar rattle
Any time i go over bumps or drive down a stress cracked road with my sunroof open it rattles like its loose in the tracks. My STEALERSHIP says this is normal. I think they are full of sh!t. It just started recently. Anyone else? Also, I'm almost positive that the black trim on the outside of the windshield is making the sound but it's not loose. The dealership has "insulated" the inside of the pillar but it still rattles. Used to I could press on the black trim and it would snap and the rattle would go away for a day or 2 till it came loose again. Now it doesnt snap like its loose. IT JUST RATTLES!!! Sorry its driving me crazy. Any ideas?
civcracker is offline   Reply With Quote
Old 01-22-2008, 09:42 PM   #2 (permalink)
I have this problem also. I brought it to the Honda dealer in Hopkins, MN and those lame a$$es could not fix it and told me that this is normal. They adjusted it and it still rattled and stated that even the new Civic's do this. I am sorry but that is not a excuse for a poor design. Getting more and more disapointed in Honda and their warranty coverage.
RSXS3 is offline   Reply With Quote
Old 01-22-2008, 10:41 PM   #3 (permalink)
VistecR's Avatar
can you give more info on the car please 2dr 4dr ex/lx/dx/Si and the year
VistecR is offline   Reply With Quote
Old 01-22-2008, 10:49 PM   #4 (permalink)
VistecR's Avatar
about the trim yeah the clips had bad design... Get new clips for it and it would fix the problem... I done couple civic in the dealer with the same problem... about the moon roof check to see if it got loose or id it needs grease, check rails for damage, rubber bushings etc
Old 01-23-2008, 08:49 AM   #5 (permalink)
mischief316's Avatar
Rude
I had the same problem with my SI. The sunroof started as a small rattle but then it got to loud. Tho mine only happened when the sunroof was closed. I took in, and got some stuff replace forgot what it was but no more rattles from the sunroof.
mischief316 is offline   Reply With Quote
Old 01-28-2008, 06:20 PM   #6 (permalink)
CruelVerano's Avatar
You've only got two rattles, good for you. Mine come from every which way. But when the weather changes so do the rattles. During winter my car drives me mad!
CruelVerano is offline   Reply With Quote
Old 11-12-2008, 02:13 AM   #7 (permalink)
sorry for bumping an old thread but im hafing the same prob, wen i tilt the moonroof and go over bumps or sumtimes on straight roads i hear like a knocking noise, only wen its tilted, wen its fully open or closed i hear no sounds... any help or suggestions would be great, thanks
ceevic is offline   Reply With Quote
Old 11-13-2008, 05:23 PM   #8 (permalink)
anyone? i tried it again last night and went on bumpy roads with my moonroof on tilt, but couldnt replicate the problem, but if there is sumfing i should be doing i would like to kno
One-Touch Moonroof Control Unit Reset Silver8th Mechanical Problems & Technical Chat 26 11-23-2008 04:42 PM
Rattle in Passenger Pillar jjohan35 Mechanical Problems & Technical Chat 17 12-12-2007 08:39 AM
Possible moonroof/headliner rattle solution DumbasSi Mechanical Problems & Technical Chat 18 11-13-2007 07:40 PM
trunk not popin' open buddhasgift2you Mechanical Problems & Technical Chat 1 09-23-2007 02:12 PM
Loud rattle / "clunking" in trunk area... HELP! Red S Eye Mechanical Problems & Technical Chat 10 02-14-2007 03:06 PM
