Old 01-19-2008, 10:29 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
Ever wonder whats in an oil filter?
Honda Oil Filter:
It's a conventional style oil filter and its reccomended for Honda's since it is an OE filter. It's internals consist of an oil port, check valve, paper element and a pressure relief valve.This does more than sufice as a Oil filter and honda doesn't even reccomend changing it at every oil change.
average cost: $6.95
Fram tough gaurd:
It's internals consist of an oil port, check valve, paper element and a pressure relief valve. It does have a difference. Note: paper element is more tightly nit and has more surface area for better filtering of oil. This filter exceeds the OEM Honda Filter. It also has a better sealing surface the seal is flat and alows for more sealing surface.
And now for the cool part. It has a screen at the base of the filter that blocks any large particles from getting int the engine.
average cost: $9.00
Mugen OIl filter:
Now for the dissapointment.....My very first oil change I used a Mugen oil filter on my honda at 5,000miles.I also switched to Mobil 1. If you look at the filter the check valve is smaller wich alows oil to recede back into the pan faster and causes oil to come out of filter which means when you start it for the first few nano seconds there is no oil to lubricate the engine. (This is when the most engine wear takes place) The box says that it has better flow well yes it does.
Anouther dissapointment...the filter element is alot smaller wich means less surface area to filter oil hence the reason for better flow not only that its the same style they use in small gas enigines like in mopeds or gocarts. not only that the pressure relief valve is so small that it it's self can get clogged causing no oil flow to engine.
To make matters worse the filter leaked all over my subframe and I lost over a quart of oil. I ended up switching it back to the OE filter. I didn't even bother trying to get my money back I was so upset over the matter I decided to do this info thread instead.
avarage cost $40.00 (shipping included)
Bottom Line: Just because something costs more money doesn't mean its better....
As for me I will be using the Fram filter from now on because it has better internals.
Hope this thread shed some light on any thoughts about using the correct oil filter.....
Next 3 pix are a close up of the filters used in Info Thread...
Originally Posted by ryker View Post
intial quality should be good when you spend 20K or more on a car. If I buy a 30.00 Polo shirt I damn well expect the buttons to stay put.
Originally Posted by fiji06si13 View Post
Well said..... now relay that message to honda......
RIP Bernie Mac
fiji06si13 is offline   Reply With Quote
Old 01-19-2008, 10:35 PM   #2 (permalink)
Rabbit's Avatar
good job man!
Rabbit is offline   Reply With Quote
Old 01-19-2008, 10:36 PM   #3 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
Originally Posted by Rabbit View Post
good job man!
thanx hope this helps clear things up for everyone...
RIP Bernie Mac
Old 01-19-2008, 10:46 PM   #4 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
Great work, also , just cuz i wouldnt spend that kind of money just to cut them up lol.
msjwild3 is offline   Reply With Quote
Old 01-19-2008, 10:50 PM   #5 (permalink)
fishermoe14's Avatar
Moe
take apart a mobil 1 :P
fishermoe14 is offline   Reply With Quote
Old 01-19-2008, 10:51 PM   #6 (permalink)
Jeremy
hmmm nice id like to see inside a mobil filter so i know whether or not im wasting my money
jeremy0203 is offline   Reply With Quote
Old 01-19-2008, 10:51 PM   #7 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
after a K&N
RIP Bernie Mac
Old 01-19-2008, 10:55 PM   #8 (permalink)
'06Siguy's Avatar
Scott
+1 Would you test a Wix filter when you get a chance. Thanks.
'06Siguy is offline   Reply With Quote
Old 01-19-2008, 10:58 PM   #9 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
You kick freakin' ass!
I would rep you if I could.
CLICK--> TOYS FOR TOTS
Old 01-19-2008, 11:03 PM   #10 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
thanx Ken
RIP Bernie Mac
Old 01-19-2008, 11:13 PM   #11 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
see the biggest problem everyone believes what is written on the boxes....
If it's to good to be true it usually is....
Fram FTW!
RIP Bernie Mac
Old 01-19-2008, 11:32 PM   #12 (permalink)
asndragonboii's Avatar
propped you!
How about the regular fram filters? The orange ones. I think the "tough gaurd" is fram's higher model.
Old 01-19-2008, 11:32 PM   #13 (permalink)
Bulli Kid's Avatar
GReg
Very nice. Good info. Test a Puralator pure 1 next time !
Bulli Kid is offline   Reply With Quote
Old 01-19-2008, 11:42 PM   #14 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
Originally Posted by asndragonboii View Post
propped you!
1. orange fram will be the same inside as OEM filter along with the WIX as well...
2. I am after the high end stuff...
3. I will try purolator pure one, mobil one, and K&N....
4. Many filters are made by the same manufacturer then sent to have different labels put on them....
the best oil filter price to spend is around 6-15 $ anything more than that and it better do more than just filter oil.....
RIP Bernie Mac
Old 01-19-2008, 11:59 PM   #15 (permalink)
c130turboprop's Avatar
what about the honda oil filters that are actually made in japan and are supposably better than the american made ones???? i heard this somewhere, i forget where though... you think they would be of quality like the fram oil filter????
c130turboprop is offline   Reply With Quote
Old 01-20-2008, 12:00 AM   #16 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
hey you should also try a HAMP filter. They seem to get good reviews around here.
Old 01-20-2008, 12:05 AM   #17 (permalink)
So do you think the Honda OEM filter is bad? Because i just bought a bunch from HandA accesories.com lol
Old 01-20-2008, 12:05 AM   #18 (permalink)
yeah, i think HAMP is what i was thinkin about....
Old 01-20-2008, 12:14 AM   #19 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
ya they (hamp filters) are from Japan.
Old 01-20-2008, 12:52 AM   #20 (permalink)
+1 rep for you. Great work & post! I decided to stick with Honda's filters for now as I'm getting them six at a time for a great discount, plus I got Hondacare's 120K mile warranty.
magbarn is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/74569-ever-wonder-whats-oil-filter.html
8th Generation Honda Civic Forum This thread Refback 01-19-2008 11:29 PM
Oil Change DIY ethlar Engine 251 12-01-2008 10:46 PM
THE OIL FAQ - synthetics, intervals, weights, brands jdrumstik Mechanical Problems & Technical Chat 98 10-16-2008 01:53 PM
Motor Oil 101 Whocares05050 Bolt-Ons And All-Motor 83 01-14-2008 06:46 PM
Mens vs Women Oil Change 06 Civic Ex Water Cooler 12 08-04-2007 12:42 PM
