Old 01-19-2008, 04:14 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
dnv
dnv's Avatar
Changing 9005 DRL/High Bulbs, need help!
I'm trying to change my 9005 DRL bulbs with yellow Nokya but I cannot pull the bulb out of the socket.
On the instruction manual it says to turn it one-quarter counter-clockwise but I've been trying for 15 minutes with no results. It seems like you cannot even turn it.
I have 08 Civic Sedan LX, if that helps. Thanks for the reply guys.
dnv is offline   Reply With Quote
Old 01-19-2008, 04:16 PM   #2 (permalink)
Truplatano's Avatar
Felix
just keep trying,
Truplatano is online now   Reply With Quote
Old 01-19-2008, 04:18 PM   #3 (permalink)
dnv
dnv's Avatar
Seems like it's mounted.
Old 01-19-2008, 05:13 PM   #4 (permalink)
shutter13's Avatar
unplug the connector and i think to loosen you twist counterclockwise facing the front of the car, once you feel it unlock then wiggle it out of place
shutter13 is offline   Reply With Quote
Old 01-19-2008, 05:15 PM   #5 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
Ya the stock high beam bulbs are a little stuborn the first time you take them out. Put a little pressure on the bulb and push in and turn it. Then it should pull right out. The drivers side you gotta take that plastic resevoir out. Good luck!
msjwild3 is offline   Reply With Quote
Old 01-19-2008, 08:22 PM   #6 (permalink)
dnv
dnv's Avatar
Gonna try again at another time, at times I almost feel that I'm gonna break the poor bulb.
Old 01-19-2008, 08:30 PM   #7 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
Thats strange, mine were tight, but not that tight.
Old 01-19-2008, 08:45 PM   #8 (permalink)
dnv
dnv's Avatar
Yeah, it felt like if I were to turn the bulb counter-clockwise it would break it out of its socket.
What car do you have? I don't know if that matters.
Old 01-19-2008, 08:51 PM   #9 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
I have an 07 si, HNBP
I dont think it should matter, then all have the same stock bulbs.
Old 01-19-2008, 10:19 PM   #10 (permalink)
shutter13's Avatar
yea its pretty weird, when i changed my hi beams to silverstar ultras it took less than 5 minutes... the only tough part was sliding the coolant overflow bottle back into place
Old 01-19-2008, 10:21 PM   #11 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
Ya that is a pain in the ass that thing.
Old 01-20-2008, 03:00 PM   #12 (permalink)
dnv
dnv's Avatar
Took me a while to put back that thing too, I don't know if I should try to remove the bulb again with the same results.
Old 01-20-2008, 03:10 PM   #13 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
Keep trying dude. It will work. You must have some stubborn bulbs.
Old 02-02-2008, 11:02 PM   #14 (permalink)
djthomi's Avatar
Tommy
I had a couple of seconds trying to get mine off too. Just jiggle it up and down when you turn it as far as you could to the left. Should pop off.
djthomi is offline   Reply With Quote
Old 02-05-2008, 09:06 PM   #15 (permalink)
dnv
dnv's Avatar
Sorry for bumping this thread, but if I were to get a set of 9005 Nokya, PIAA or Luminics , would it come with the socket so I can just plug it into my connector?
This is what I'm talking about:
If I were to get this, would it come ready like the picture on the right so I can just disconnect my old DRL from the connector and simply plug in the new stuff?
Help is much appreciated! Thanks guys!
Old 02-06-2008, 01:55 AM   #16 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
Ya as long as they are 9005's they will fit in the high beams, which are your DRL's. Just take the old ones out and put these ones in and your good to go.
Old 02-06-2008, 12:05 PM   #17 (permalink)
9005 = Low Beams
9006 = High Beams/DRL
Old 02-06-2008, 12:11 PM   #18 (permalink)
dnv
dnv's Avatar
Originally Posted by av911 View Post
9005 = Low Beams
Uhh.. 9005 is DRL/High Beams..
Old 02-06-2008, 12:14 PM   #19 (permalink)
dnv
dnv's Avatar
Thanks msjwild3. I'm gonna get a set of Nokya 9005 yellow tomorrow and try it out, I will post pics of the result.
Edit: Tried repping you, but it says "You must spread some reputation around before giving it to msjwild3 again."
Old 02-06-2008, 06:37 PM   #20 (permalink)
8th Civic Addict
msjwild3's Avatar
Ryan
Haha that's alright. Ya lets see how they look. It's an easy install.
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/74495-changing-9005-drl-high-bulbs-need-help.html
8th Generation Honda Civic Forum This thread Refback 01-19-2008 08:22 PM
DRL...changing bulbs to other? Kabs Inside and Out 41 11-04-2008 08:15 AM
NOKYA bulbs for DRL's/Highbeam...9005 or 9006? JaY_JaY Lighting, H.I.D.'s, & Neon 1 11-27-2007 04:53 AM
question about changing stock light bulbs 1sole Lighting, H.I.D.'s, & Neon 1 11-10-2006 05:32 PM
Changing Bulbs besterino Lighting, H.I.D.'s, & Neon 12 05-14-2006 02:40 AM
