Old 01-18-2008, 10:53 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
SIcivic07's Avatar
Dan the DIME slayer
Alignment or what?
so, my FA5, i dont know if this needs an aligment or what is up, but for a while now, my steering wheel would have to be a few degrees to the left in order to travel straight, and yes, i have tried on a completely flat surface. once i turn the wheel completely straight, i go slightly to the right...is this the sign of a needed alignment?
SIcivic07 is offline   Reply With Quote
Old 01-18-2008, 10:55 PM   #2 (permalink)
Teebo07si's Avatar
TEEBO!!
check the tire pressure!
Teebo07si is offline   Reply With Quote
Old 01-18-2008, 11:27 PM   #3 (permalink)
younglexx's Avatar
Alex
My FA5 does the same and I've only had for 3 months and it's been doing it for at least 2 months. But it isn't super noticeable
younglexx is offline   Reply With Quote
Old 01-18-2008, 11:27 PM   #4 (permalink)
kshakeylude20's Avatar
how did that happen to you? did you hit something on the road or what? because if u do hit something on the road or hit a curve maybe your subframe got messed up.
kshakeylude20 is offline   Reply With Quote
Old 01-18-2008, 11:55 PM   #5 (permalink)
socalsedan's Avatar
Bryan
I have the same problem dude. I place the steering wheel straight and slide slightly to the right. But then again...i do have 7k on it.
socalsedan is offline   Reply With Quote
Old 01-19-2008, 12:10 AM   #6 (permalink)
just take it to the dealer and they will take care the problem of your car. i believe is the subframe moved to either left or right.. because me i hit a f****n curve and messed up my rsx S wheels and mah subframe. but the best part was i have a lot of fun and it was so good. my GF giving me some and lose my attention then bammm hit a curve
Old 01-19-2008, 12:11 AM   #7 (permalink)
mine moved like at least 40 degrees to the right
Old 01-19-2008, 12:18 AM   #8 (permalink)
soxfan143's Avatar
I had the same problem. It did it since the first day I owned it. I was pissed. I am a tech tho so I did my own alignment. Go back to Honda and it should be under warranty. How many miles on your car now? If you have under 12000 they should do it for free. And as long as it doesn't look like you hit anything you should be fine. So any of you guys with brand new ones go back to Honda and bitch. There is NO reason for a car to not go straight when it's brand new.
soxfan143 is offline   Reply With Quote
Old 01-19-2008, 01:02 AM   #9 (permalink)
asndragonboii's Avatar
Not a wheel alignment. The steering wheel needs to be realigned. 3 cars ive driven have this "problem". The same thing you described. The car doesnt PULL, it just doesnt go straight when the steering wheel is straight... the steering wheel has to be to the left a tiny tiny bit.
197x Mercedes
1998 Dodge Dakota
2006 Civic.
Old 01-19-2008, 04:30 AM   #10 (permalink)
tite681's Avatar
USDaMn
I had the same problem at 9.2k miles. Honda found it out of spec and fixed it under their 12/12 warranty.
tite681 is offline   Reply With Quote
Old 01-19-2008, 10:52 AM   #11 (permalink)
SIcivic07's Avatar
Dan the DIME slayer
i have 12500K lol...will they still do it for free? andd no, i never hit a bump or a curve to mess up my frame like that.
Old 01-19-2008, 01:15 PM   #12 (permalink)
mine does the same thing.. looks like they all do it.. way to go honda
08blacex is offline   Reply With Quote
Old 01-21-2008, 12:58 AM   #13 (permalink)
SIcivic07's Avatar
Dan the DIME slayer
well, looks like im not the only one. so, i guess ill just wait for them to look at it until i take it for the 15k check up. i have 12,500 miles now. its not such a huge burden
Old 01-21-2008, 01:04 AM   #14 (permalink)
younglexx's Avatar
Alex
im going to try and take my car in tomorrow. I have 7K on it so they should cover it. I'll let you guys know what happens.
Old 01-21-2008, 01:09 AM   #15 (permalink)
msqr's Avatar
I say leave it. From personal experience, the alignment won't make that much of a diffeence. It's probably just our soft and electric steering.
msqr is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/74403-alignment-what.html
8th Generation Honda Civic Forum This thread Refback 01-18-2008 11:25 PM
Who has gotten an Alignment? Highrev1 Suspension and Brakes 73 09-27-2008 02:07 PM
Specs for a wheel alignment llckll Suspension and Brakes 6 11-20-2007 07:58 PM
Anyone done an alignment? SoFLACiViCSi06 Mechanical Problems & Technical Chat 10 07-31-2007 04:38 PM
good alignment shops in the southbay? junsu California South 1 11-30-2006 08:01 PM
fg2 alignment? subieguy83 Suspension and Brakes 0 04-04-2006 08:34 PM
