#2 (permalink) | |
another thing is that they really do just barley make it but the accelerator is flimsy and is able to wiggle side to side. when i barley get it with my shoe on it it just moves out of the way. |
I also have difficulty, I wear driving styled shoes which are very slim and in order to heel and toe, I actually have to use my heel as opposed to the right side of my right foot. I actually purchased an extended pedal and will post a DIY when it arrives. The company I purchased it from agreed to offer free shipping to our forum if I can setup a group buy. It should come on Friday.
The McGyver ofall McGyves
![]() Join Date: Jun 2007
Bart Koscow
ha no prob here, i keep my heel right under the brake, and just rotate, my toe hits the middle of the pegle with no prob. but i drive in high top 16hole army atile steel toed boots.... and i have a canoe sized 13 for a foot, so that helps.
so i either drive in my boots or bare foot... NP's here. |
#7 (permalink) | |
Added a picture:
#10 (permalink) | |
Kill Your Self Krew
#12 (permalink) |
HT shouldn't be a problem. Try these tips:
1. Anchor your heel at the base of the gas pedal. 2. When braking, rotate your toes in a counterclockwise position (while keeping ankle at base of gas pedal), and press on the right half of the brake pedal with the left ball of your foot to initiate braking. 3. Roll foot over to the right (outside of your foot should be depressing the gas pedal at the moment) to blip the gas. At this point, your foot should be touching 3 places: heel at base of gas pedal, leftside of the ball of your foot depressing the right side of the brake pedal, and the right outside of your foot should be hitting the gas pedal. 4. Mind the rev hang: If your A/C isn't on, then your revs will hang once you blipped it to the correct RPM for the lower gear. Pause a split second before releasing the clutch (can release right away if A/C is off, or the car hasn't warmed up yet). 5. Shoe size: The wider the shoe the better. If you have a narrow shoe, like a puma driving shoe, you have to press the brake pedal down further (more braking) in order to line your foot up with the gas pedal. So for around town driving, I suggest a wide shoe that has a thin sole. Hope this helps. |
#15 (permalink) |
Although traditionally called Heel and Toe, even racing drivers use ball of foot (below the big toe) and right side of foot (upper to mid section). If you've ever tried to actually use your heel and toe, you'll notice it is much more difficult to achieve steady braking when you need to bend your ankle so far that your heel touches the throttle.
#16 (permalink) | |
Also my foot is almost always floating between the brake and gas pedal which is counter intuitive to the floor hinged throttle found in our civics. Last edited by habitat; 01-17-2008 at 03:58 PM. |
#17 (permalink) | |||
#18 (permalink) |
I'm 6' tall and wear size 10 shoes.
Everybody can give this a try on their drive home tonight and see if this works for you: use ball of right foot to depress (1/3 to 1/2 way down) right half of brake pedal, while anchoring right heel at base of gas pedal. When you brake this way, your foot should be hitting the gas pedal if you just roll it over to the right. |
#19 (permalink) | |
#20 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/74126-do-you-have-difficulty-doing-heel-toe-your-8th-si.html
| 8th Generation Honda Civic Forum | This thread | Refback | 01-17-2008 01:08 PM | |
| Heel and Toe shifting explained. Video! | radiocontrolhead | Driving Experience | 35 | 09-06-2007 08:55 AM |
| Heel and toe / Pedal Adjustment | schield | Driving Experience | 3 | 07-09-2007 08:24 PM |
| Heel and Toe | fg2k20z306 | Civic SI | 20 | 12-01-2006 04:09 PM |
