Old 01-12-2008, 10:25 AM   #1 (permalink)
Removing mirror from side mirror housing...
I just bought my 06 si coupe, and the driver's' side mirror (the actual mirror itself) has scratches on it...I tried to get these out with various things, but I've decided to just replace the mirror because it is 15 bucks from Honda. Can the mirror just pop out or do I have to completely remove the housing to get it out?
tarh33l10 is offline   Reply With Quote
Old 01-13-2008, 12:40 PM   #2 (permalink)
bump...
Old 01-13-2008, 12:41 PM   #3 (permalink)
As far as I remember there are screws underneath the mirror to take it apart. Nothing is ever as easy as just to pop out.
xxhaimbondxx is offline   Reply With Quote
Old 01-13-2008, 04:20 PM   #4 (permalink)
alright, how is the mirror attached?
Old 01-13-2008, 04:24 PM   #5 (permalink)
u have to take off the inside door panel to take the mirror off... then try the screws... i personally haven't done this so a DIY with pix will be nice if u do this... my drivers mirror is scratched also... my fault of course
Old 01-13-2008, 05:36 PM   #6 (permalink)
that's what i'm afraid of, i hate to take off the door panel just to change that mirror piece
Old 01-13-2008, 05:40 PM   #7 (permalink)
i'll look at it now... brb
Old 01-13-2008, 06:35 PM   #8 (permalink)
DIY Mirror Replacement
Old 01-14-2008, 11:21 AM   #9 (permalink)
thanks man, just what i was looking for
Old 06-02-2008, 09:14 PM   #10 (permalink)
07 Figi Blue Si's Avatar
Lance
This is NOT TRUE. You do not have to take off the door panel to change the mirror, on an Si at least. Maybe others, since mirror is mounted to door.
For Si, pull straight out the corner triangle plastic piece, held on by metal clip. You will see two screws under it. In the corner, there is a cover cap. Remove it. There is the third screw. Remove all three screws, and unplug the electrical connector. Depress on both sides of the electrical connector housing, there are two plastic protrusions. Hold the mirror from the outside while depressing, because these two plastic protrustions are the last thing holding the mirror in place. Remove the mirror.
07 Figi Blue Si is offline   Reply With Quote
Old 08-15-2008, 12:15 PM   #11 (permalink)
you're right
Passenger Side Door Lock Squeaking? dt07Si Mechanical Problems & Technical Chat 22 09-27-2008 01:51 AM
One side works other side doesn't? asdf Lighting, H.I.D.'s, & Neon 7 10-02-2007 07:44 PM
Removing rear side panels in coupe? Phlipcyde Do It Yourself Articles 2 06-08-2006 12:18 AM
06 Coupe driver side door issue racerX Civic Coupe And Sedan 6 03-31-2006 04:13 PM
