Old 01-11-2008, 12:04 AM   #1 (permalink)
rp215's Avatar
Ronnie
Won't Start On First Try
Does anyone else have an issue where you turn the key to start and it doesn't. I'm not talking about where it turns over and never fully starts. It seems that sometimes (randomly) when I put in the key and turn the ignition it is dead silent and the car does not even attempt to start. Couple more clicks and finally it turns on without hesitation.
Just started happening 3 days ago. Im bringing it in to Honda tomorrow however I just wanted to know if anyone else has had this problem in the past? And the fix for it?
rp215 is offline   Reply With Quote
Old 01-11-2008, 12:06 AM   #2 (permalink)
Undispu7ed's Avatar
Jon
Your foot has to be on the clutch all the way down. Starting the car is different than shifting gears. Shifting gears, you find where the clutch grabs. Starting the car is different....if that's not the case, then no never had that problem.
Hardships of my RR Si http://www.8thcivic.com/forums/intro...k-anymore.html
Undispu7ed is offline   Reply With Quote
Old 01-11-2008, 12:13 AM   #3 (permalink)
a1rfreshener's Avatar
mike
naw dont got this problem....but once wen i was drunk nd was coming home form a party....which was only down the block i couldnt start my car because i forgot to engage the clutch :\ haha but i think it can be ur relay wires or maybe even the starter.....wish u luck on that one man
a1rfreshener is offline   Reply With Quote
Old 01-11-2008, 03:26 AM   #4 (permalink)
rp215's Avatar
Ronnie
Trust me clutch is all the way down. I even released it and pressed it again to make sure I wasn't crazy and still wouldn't start. Sometimes it takes one try, sometimes two, sometimes three, sometimes it doesn't hassle me.
This sucks!
Old 01-11-2008, 05:33 AM   #5 (permalink)
The McGyver ofall McGyves
portabuddy's Avatar
Bart Koscow
sounds like a ignition problem... post a pic of your keychain, if it weighs 20lb then thats your problem. your anti theft isnt recagnizing your key and wont start... then when you jiggle or take out/reinstall the key it recognizes it cuz it sits proerly in the barral
fairly common... you might need a new ignition assy.
portabuddy is offline   Reply With Quote
Old 01-11-2008, 04:13 PM   #6 (permalink)
Jason
not necessarily. as long as the "switch" the clutch pedal activates to start the car is "on", then it'll start up, even if the clutch may not be all the way down.
Old 01-11-2008, 05:07 PM   #7 (permalink)
Good to know. Care to know how many friends and family I've had killed by drunk drivers?
Orbit1 is offline   Reply With Quote
Old 01-11-2008, 09:21 PM   #8 (permalink)
BigT's Avatar
Any news?
It could simply be a bad battery or a loose battery connection. Hopefully it is something simple.
BigT is offline   Reply With Quote
Old 01-11-2008, 09:47 PM   #9 (permalink)
NHPB ftw
Arganon's Avatar
Gordon
Check if the terminal connections to the battery are not loose. This exact same thing happened to me a few weeks back, my positive terminal connection was so loose you can take it off without unscrewing anything.
Arganon is offline   Reply With Quote
Old 01-12-2008, 12:25 AM   #10 (permalink)
Garrett
I've been having similar issues with the clutch all the way depressed. 2007 Si Sedan. Never takes more than 2 tries though. I'll probably take it into the dealer sometime soon to get it checked out among other things.
garrnew is offline   Reply With Quote
Old 01-12-2008, 12:40 AM   #11 (permalink)
soxfan143's Avatar
Ya driving around drunk isn't cool bro. You're lucky you didn't kill someone. More accidents happen within a mile from your house than anywhere else. Don't be an Idiot and walk next time if you were only down the street.
But anyway, I had a loose positive terminal also. It would lift off randomly and then fall back on so when I would try to start it it wouldn't start but when I got out to look under the hood the terminal would fall back on the battery post when I would close the door. Finally I got lucky and for some reason I didn't shut my door one time when I checked it out and it was completely off the batt.
soxfan143 is offline   Reply With Quote
First look at the Civic OEM Remote Start System CollegeHillsHonda Inside and Out 76 12-05-2007 08:48 PM
remote start Q's m1k3 I.C.E., Electrical, Security, & Navigation 1 10-14-2007 05:22 PM
CLUNK: How to start or park car on incline ? goixiz Mechanical Problems & Technical Chat 22 09-24-2007 01:59 PM
Cold Start Idle Stays Hi Too Long Ehcees Mechanical Problems & Technical Chat 46 07-27-2007 01:19 AM
