Old 03-01-2008, 05:15 PM   #21 (permalink)
Jason
^is that u in the picture?
Old 03-01-2008, 05:18 PM   #22 (permalink)
Asif22's Avatar
Mohamed El-Mubaslat
I don't do burn outs or anything but when ever I am done driving the car I smell something weird may be the clutch or not. idk
Asif22 is offline   Reply With Quote
Old 03-01-2008, 05:41 PM   #23 (permalink)
deltatechx's Avatar
Angry
What kind of burnout did you do? Did you just drop the clutch at high rpm, or did you play with the clutch to get the car moving a bit then drop it (this puts much less stress on the car and its parts)?
If you can accelerate at full throttle in all gears without any abnormal engine rev, your clutch is fine. When I first got my 06 LX sedan, I had the same problem with the clutch disengaging after barely depressing the clutch pedal, after driving it for a few thousand miles it "reset" itself and now requires me to fully depress the pedal, so you should be able to drive it out (if you drive it properly). If it continues to smell, think of it as your car punishing you for treating it like shit. Dropping the clutch causes so much stress within the engine, tranny, engine mounts, bearings, axles, unibody, tires, control arms, bushings, struts, alignment, shall I go on? Burnouts are nothing but a sign of weakness in your suspension, so it's not showing off. If you must do burnouts, please replace all the above with performance parts, otherwise you take a multi thousand dollar chance every time you drop the clutch.
These cars are designed to last as long as you treat them right, I've got 160,000 miles on mine and haven't replaced anything (shocks, and struts do need to be replaced tho), the clutch is still holding strong.
deltatechx is offline   Reply With Quote
Old 03-02-2008, 12:44 AM   #24 (permalink)
27IVTEC's Avatar
Jones
He already got a stage 2 clutch and a light weight flywheel, so he wont be having this problem for while.
27IVTEC is offline   Reply With Quote
Old 03-02-2008, 01:09 AM   #25 (permalink)
Ears bleed at 70mm
sh33t_0f_p4p3r's Avatar
Tobie
my clutch is fine, probly bc i drive my SIdan like a grandma :-(
sh33t_0f_p4p3r is offline   Reply With Quote
Old 03-05-2008, 03:11 PM   #26 (permalink)
edrhee83's Avatar
Ed Rhee
Exactly~~
edrhee83 is offline   Reply With Quote
Old 03-05-2008, 04:44 PM   #27 (permalink)
Leonard1818's Avatar
Leonard
So how's the new clutc/fly working out for ya? Alls well?
Leonard1818 is offline   Reply With Quote
Old 03-05-2008, 04:56 PM   #28 (permalink)
edrhee83's Avatar
Ed Rhee
It's working out great. Definitely improvement on power. More torque to me. And it does not slip. Only thing for me is that my syncronizer might be bad now. Boo Honda Tranny.....
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/72689-i-think-i-wore-out-clutch.html
8th Generation Honda Civic Forum This thread Refback 01-08-2008 02:58 PM
Newbie guide for Manual Transmissions Tastycakes Mechanical Problems & Technical Chat 131 07-02-2008 02:05 AM
Exedy Hyper Single Stage III Clutch Kit: Part Details (PIC Heavy) blueroadster Forced Induction And Nitrous 103 12-18-2007 11:23 AM
how to choose a clutch material! jsb03f Bolt-Ons And All-Motor 2 12-05-2007 11:52 AM
Stage 3 Clutch Problem -Help- SC06SI4U2NV Forced Induction And Nitrous 28 07-04-2007 11:47 AM
ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust skittleslegend Civic SI 43 06-22-2006 08:34 AM
