#41 (permalink) | |||
Typical. How Typical.
#43 (permalink) | |
Automotive Articles .com Magazine | Automotive Articles Magazine I will come back and update this thread as well but I won't have as much time to give details on all the forums. But to answer the question... I have talked to several people who have the same issue you have. And some of these people are not lucky enough to have 4 different Honda shops close to them to jump around for second opinions. I will suggest what I suggested to them. If you don't have many dealers around... 1. Have your visits to the dealer documented. 2. Wait for the TSB. 3. Call you dealer, make an appointment to come in and talk to the service manager. Don't do it on the phone, they are often busy or won't want to deal with you. Go in talk with them. Explain that you have had the problem since taking delivery of the car. You have brought it in several times without help. And ask them to see if they know anything about it. If they do not look up the TSB right away while you are there you politely offer up the notion that you have called around to different dealers and they told you that Honda has a fix just released for this and they have been repairing other cars with the same issue. You want the dealer to look up the TSB without you telling them to do it namely if you are dealing with a place that is difficult. If they still don't look it up ask them for an email address so you can send him the articles which at that point will have TSB info on it. Worst case if the service manager still does not help go to the front desk and ask to talk with the general manager, make an appointment if needed to talk to them. Always calmly explain what is going on and let them know you need THEIR help. They will want you to bring the car in. It is best to drive with a mechanic. Let him drive and then you drive. Take as much time as you need until you can recreate it. Maybe leave your car there overnight, have someone drop you off in the morning and take the mechanic out during a cold start to help make the problem worse. If you still can't get help last resort is opening a case with Honda customer service and dealing with a district manager from Honda. My guess is that this TSB will be very well known. If your complaint matches the TSB description dealers will have no problem swapping in the parts. |
#44 (permalink) |
I just want to clearify something
Does the 3rd gear issue also have to do with the 3rd gear feeling like theres knotch in it? cause i KNOW if i don't push it hard enugh sometimes..that it will pop out/grind.. edit-nvm, the second video told me i was right
#48 (permalink) |
I've noticed the shifting problem at a little above 4K miles. At first I thought it was just me but I've own several manual cars before and never had a problem. Then I found this forum and changed out my fluid with a synthetic one. I definately noticed a difference in shifting. Shifting was smoother but it did NOT fix the problem but it did help the tranny. Now at almost 16K miles, I still get the occasional grind and two pop outs due to an incomplete shift. I did notice however that when shifting to third gear sometimes, I can feel 3 clicks before I am confident enough that is indeed in gear. I do get the occasional grinds on first and second but it doesn't happen too often. So the fluid change doesn't fix the problem, it only hides it and I just take extra care when shifting to third. I would hate to think what kind of shifting problem I would have if I didn't change the fluid.
#49 (permalink) | ||
They have, several times.
One time, in particular, it not only grinded, but popped out of gear, and when I asked the tech if he heard of saw it, he said "Oh, I didn't see or hear it."
#50 (permalink) |
Here is a thought of mine to add fuel to the fire...
Is it possible that the popping out of 3rd gear or not going completely into is being caused by the shift cables or shifter itself and not by the transmission? Example... The driver is accelerating and the motor is moving around because of the torque. The motor moving around slighly while under load is "pulling" on the shift cables and pulling the shifter out of gear. |
#53 (permalink) | |
If you need any other information on this car just send me a message or reply here. I can answer any questions you may have
#56 (permalink) | |
#59 (permalink) | |
I have talked with Brian and Ed in Honda service at Motorwerks several times about this. For most dealers it is simple. They will not go out of their way to investigate an issue. They want it to come up on their system in 5 seconds when they do a search for the TSB or the problem does not exist. All of these guys have access to a local service rep and tech line. Getting them to call is like asking God to talk to you sometimes. |
#60 (permalink) | ||
Reese
my other question is...my car aleady has 45k miles on it so its obvious that its out of warranty. however, being it a TSB, is my car still covered? will i have to pay anything extra or will i be taken care of the same way as a customer thats still has warranty on their car. |
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/72406-honda-6-speed-manual-dilemma-article.html
| RSX-s Transmission Problems?? - TriStateTuners.com :: Home of Tristate Auto Enthusiast | This thread | Refback | 01-29-2008 03:59 AM | |
| RSX-s Transmission Problems?? - TriStateTuners.com :: Home of Tristate Auto Enthusiast | This thread | Refback | 01-21-2008 07:34 AM | |
| RSX-s Transmission Problems?? - TriStateTuners.com :: Home of Tristate Auto Enthusiast | This thread | Refback | 01-20-2008 03:36 PM | |
| Auto Parts » Honda 6 Speed Manual Dilemma - Article | This thread | Pingback | 01-08-2008 07:30 AM | |
| Auto Parts » Honda 6 Speed Manual Dilemma - Article | This thread | Pingback | 01-08-2008 07:08 AM | |
| Auto Repair » Honda 6 Speed Manual Dilemma - Article | This thread | Pingback | 01-08-2008 06:56 AM | |
| Honda hypes reliablity with Mile Makers - Autoblog | This thread | Refback | 01-07-2008 05:50 PM | |
