What are some reasons for such low mpg?
I bought my 2006 Civic LX in November and got about 24 mpg. Over the last few weeks it has been extremely cold and my mileage went down to 14. What could be causing this besides for possibly the cold weather? I had the car checked today and the air filter, oil and sparkplugs were fine. what can it be?
#7 (permalink) | |
it could be a number of reasons.
1.how long do you let your car warm up?...this is obvious. 2.what is the average distance you drive your car?...the longer you drive, the better mileage you get. short trips to the local store dont allow the car to get to its potential. 3.cold weather takes longer for the car to warm up, car has a high idle when cold, therefore using more gas. 4. winter gas is notorious for shitty mileage. factoring in all these things...the worst i could think of would be low 20s....mileage in the teens from an r18 is bad, i would ask the dealer but chances are they will blame your driving habit. the only way for them to diagnose would be to use your car for a couple of tanks of gas, and i dont think you want all that mileage on your car...especially from the dealer. |
#10 (permalink) |
![]() Join Date: Feb 2006
Back and Forth Forever
Everyone else is correct, something doesn't seem right. One more thing to factor in, how do YOU figure your gas mileage? That could be the problem as well. Let us know.
#14 (permalink) | |
all that plus tire pressure and incorrect oil weight??? |
#16 (permalink) |
Are you using 5W-20 motor oil? Using a heavier weight can negatively impact fuel economy during the winter months, especially if you do a lot of short trip driving where the engine barely reaches operating temperature before the engine is shut off.
If you are already using 5W-20, and depending on how cold it gets where you are, you may want to consider trying a synthetic oil (Pennzoil Platinum, Mobil 1, Royal Purple, Amsoil, etc). These oils flow better when the temperature falls. When is the last time you replaced your engine air filter? Best practice is to replace the engine air filter once per year or every 15,000 miles, whichever comes first. Fuel quality could be part of the problem as well. Try buying gasoline at a different station and see if your MPG's improve. You may also want to try using a fuel system cleaner, such as RedLine, in a tank of gas about 1-2 weeks before you change your oil. Some of the fuel system cleaner may enter your engine oil and break it down, hence it is best practice to use these cleaners just prior to an oil change. |
#19 (permalink) |
Rene....
-wrong oil weight
-low tire pressure -brakes biding -low quality gas -driving habbits -cloggged intake -Bad o2 sensor -more weight inside car(trunk-passangers) -unusual timing |
#20 (permalink) |
-Using too much AC
-Opening windows wide open and driving on freeway fast (hope ur not in winter heheh) - Keeping it in high RPM - Riding on brakes - Fuel leak - Bad ECU (O2 sensor is only for idle, not open throttle) Even all those factors, it's abnormal to have such crappy MPG. My Si I've been flooring it and keeping it around 5k RPM in 50-60 deg weather and I'm looking to get 22-24 mpg. |
| Low Power Steering Fluid | victor | Mechanical Problems & Technical Chat | 15 | 02-04-2008 09:55 PM |
| How Low Should I Go? | CivSi06 | Civic Coupe And Sedan | 6 | 04-17-2007 12:22 PM |
| R-18 gives it up. Great MPG!!! | psyshack | Civic Coupe And Sedan | 73 | 10-14-2006 03:57 PM |
| AIR MODS AND MPG LOSS?? | jehu4u | Garage | 3 | 03-26-2006 01:29 PM |
