Old 05-09-2006, 03:25 PM   #1 (permalink)
ntwrkguy's Avatar
Shifting from Park to Reverse (eventually to D)...
Hey-
I have been noticing more that when I am about to pull out from a parking space (slight hill) that my Civic LX AT has been sitting in overnight, the shifter is tough to move from P to R (not like N to D), and when it goes to R, I can hear it, and it lurches a little...
Is this just normal operation of the car?
ntwrkguy is offline   Reply With Quote
Old 05-09-2006, 03:27 PM   #2 (permalink)
CHRIS's Avatar
Originally Posted by ntwrkguy
Hey-
ya i think so, cuz of the slight hill part
CHRIS is offline   Reply With Quote
Old 05-09-2006, 03:28 PM   #3 (permalink)
CameronJr9's Avatar
Back and Forth Forever
If you park on a hill like that, as you're parking, hold the brake, place the car in park, use the e-brake, then let off the brake.
When you get in it again, hold the brake, let off the e-brake, put the car in drive/reverse and then let off your brake.
Did that make any sense? That should get rid of the lurch.
Old 05-09-2006, 04:31 PM   #4 (permalink)
amdhunter's Avatar
Hey-
Yeah, it is kinda normal for a nice healthy transmission that has just been turned on.
It's when the transmission doesn't kick in for a second or two after shifting, that you start to worry. :)
amdhunter is offline   Reply With Quote
Old 05-09-2006, 05:21 PM   #5 (permalink)
push on the brake pedal, shift into netrual first....then shift into R, this way it takes some of the weight off your transmission, also put your parking brake on,.. again to take of the weight of your car from your tranny
hope that helps alittle
2006SI is offline   Reply With Quote
Old 05-09-2006, 06:33 PM   #6 (permalink)
^^ How can you shift into N before R when the shift pattern is P R N D D3 2 1???
GGSedan06 is offline   Reply With Quote
Old 05-09-2006, 06:36 PM   #7 (permalink)
Webby's Minion
8thgenuser's Avatar
Nikon Squad Member #8
GGSedan06 was referring to an automatic tranny.
2006SI was referring to a manual tranny.
Old 05-09-2006, 06:43 PM   #8 (permalink)
Webby's Minion
8thgenuser's Avatar
Just get in the habit of doing what Cameron said all the time...even on flat, horizontal roads. I do it all the time, with the exception that once I have my foot on the brake pedal, I let go of the e-brake and then shift into gear. I don't have any problems with lurching forward/backward.
If you make it a routine, you won't have to remember it whether or not you are parking on/pulling away from a hill.
Old 05-11-2006, 04:18 PM   #9 (permalink)
Hey-
uhh yeah its called torque lock.
jayjr98 is offline   Reply With Quote
Chef Leaves South Park Rainman Water Cooler 8 01-16-2007 03:44 PM
