Old 12-02-2007, 08:15 PM   #1 (permalink)
20civic07's Avatar
initial idle odd.
well i have an intake system on my car, and it is just a little weird when i start the car when the engine is cold. I'll start it up, and it'll sit and idle at around 1900ish rpms for a few moments, and then it'll jump down to 1500 and idle there... is this normal or something i should be worried about?
20civic07 is offline
Old 12-02-2007, 08:16 PM   #2 (permalink)
Derka Derka!
solidust's Avatar
BOB SAGET!
how long do you wait
solidust is offline
Old 12-02-2007, 08:24 PM   #3 (permalink)
20civic07's Avatar
it gives it a good 45 sec i think.. and when i mean idle there, the car isnt warmed up yet, but it idles normally when warmed up.
Old 12-02-2007, 08:27 PM   #4 (permalink)
WHOcaREs05050
Whocares05050's Avatar
Of course its normal, lol. You never noticed it when it was stock? The engine runs in open loop / little rich at startup and runs a little high in the rpm range. The Oil pressure is slightly higher as well. The purpose of this is for the cat system. The car needs the cat at full operating temps for it to work correctly, and it needs to heat it up quickly. Perfectly normal.
Whocares05050 is offline
Old 12-02-2007, 08:28 PM   #5 (permalink)
CapnCrunch926's Avatar
Any car does this. Some cars do it to a greater extent, but on a cold start you'll always see a higher idle for a bit.
CapnCrunch926 is offline
Old 12-02-2007, 08:32 PM   #6 (permalink)
nayilsi's Avatar
nOOb ur fine
nayilsi is online now
Old 12-02-2007, 08:41 PM   #7 (permalink)
20civic07's Avatar
i didn't quite notice when stock. i know it does it, but it felt like it SUDDENLY drops down to 1500 rpms. like it'll idle high then SUDDENLY go to 1500 rpm. was just a question... i am paranoid everytime something sounds like it goes wrong with a car..
Old 12-02-2007, 08:46 PM   #8 (permalink)
dorkiedoode's Avatar
what till you hear your gear grind.
dorkiedoode is offline
Old 12-02-2007, 08:50 PM   #9 (permalink)
20civic07's Avatar
already do... problems with civic = too many
Old 12-02-2007, 09:05 PM   #10 (permalink)
WHOcaREs05050
Stop looking for problems and enjoy your purchase for what it is.
Old 12-02-2007, 09:12 PM   #11 (permalink)
Jason
AllShowNoGo is offline
Old 12-03-2007, 02:03 AM   #12 (permalink)
Gregwire's Avatar
Greg Godwin
My old car (89 sunbird turbo) used to idle at almost 3K when I first started it cold. It would take a good 3-5 min for it to come down as well.
Gregwire is offline
Old 12-03-2007, 07:19 PM   #13 (permalink)
Andrew
i posted up a thread that addressed the same issue
it's because the engine's a high compression engine and all that warming up junk
nothing to worry about
just don't push it till it's warmed up all the way and you're fine
andreewlee is offline
Old 12-03-2007, 07:31 PM   #14 (permalink)
mine is stock and once it a while it will do that fast drop to 1500. 2000 for about 45 secs and then a quick drop to 1500. this only usually happens after the first initial cold start, then it sits all day (at work for instance) and then i start it to go home it might do that.
dnbsi is offline
Old 12-03-2007, 07:43 PM   #15 (permalink)
Derka Derka!
solidust's Avatar
BOB SAGET!
I usually wait like 10 min until the car is under 1k
solidust is offline
Old 12-03-2007, 07:44 PM   #16 (permalink)
rmfa's Avatar
Ronnie
Another idle thread? Please stop. Your car is just working as designed. Is there something in the manual about this? Quit complaining and drive it or sell it.
rmfa is offline
Old 12-03-2007, 08:22 PM   #17 (permalink)
DTNguyen107's Avatar
It's normal......period...
DTNguyen107 is offline
Old 12-03-2007, 10:18 PM   #18 (permalink)
WHOcaREs05050
Who the fucck would turbo a sunbird? lol
Old 12-03-2007, 11:59 PM   #19 (permalink)
soxfan143's Avatar
lol. Thats funny
soxfan143 is offline
Old 12-04-2007, 12:08 PM   #20 (permalink)
radiocontrolhead's Avatar
Danny
You're odd and your car is normal.
radiocontrolhead is offline
Cold Start Idle Stays Hi Too Long Ehcees Mechanical Problems & Technical Chat 46 07-27-2007 12:19 AM
AC compressor cycling frequently at idle rationull Civic Coupe And Sedan 5 07-02-2007 01:37 PM
Initial thoughts on the skunk 2 sedan conversion..fyi jimmychoi Bolt-Ons And All-Motor 12 05-25-2007 10:55 PM
civic ex cp engine knocking sound on idle oplok72 Civic Coupe And Sedan 35 05-03-2006 10:00 AM
Idle point for MT's taste Civic Coupe And Sedan 14 05-01-2006 09:29 PM
