08 civic hesitation?? - 8th Generation Honda Civic Forum
Old 11-10-2007, 03:02 PM   #1 (permalink)
Ok i just bought my 08 civic ex only has 300 miles on it.. at low rpms andything uncer 3500 it will stumble or hesitate while under accelerating or just driving.. does anyone else have this problem? should i just take it in to see what the dealer will say? I really wasnt expecting this from my brand new honda..
08blacex is offline
Old 11-10-2007, 03:10 PM   #2 (permalink)
Scrodums
Do you mean hesitation when you hit the gas? For example, you hit the gas and get a delay in response? If so, that's just drive-by-wire lag.
Old 11-10-2007, 03:18 PM   #3 (permalink)
no theres no delay but if your just cruising at part throttle it will buck/hesitate then pick up above 3krpms
08blacex is offline   Reply With Quote
Old 11-10-2007, 03:25 PM   #4 (permalink)
Eric
my 07 si does the same thing
13secsi07 is offline   Reply With Quote
Old 11-10-2007, 03:41 PM   #5 (permalink)
EvilSardine's Avatar
Jonathan
I have never driven an automatic civic, but I would imagine it's the low torque of these cars?
If I step on my gas in 4th gear while my RPMs are at like 2k, my Si isn't going anywhere soon until it goes above 3k or so. These cars like to rev high. =)
EvilSardine is offline   Reply With Quote
Old 11-10-2007, 03:43 PM   #6 (permalink)
its a man. tranny not an auto.. fells like a car with a tune out of wack but its stock and new!!!!
Old 11-10-2007, 04:11 PM   #7 (permalink)
Jonathan
Well, you have to be in the right gear in these low torque cars if you want to mash the gas like that.
If I'm in 5th and I need to accelerate fast then I will drop it to 3rd with a nice fast rev match and now my RPMs are high and my car will actually move when I slam on the gas. =)
Your car has less power than mine so I'm sure it's worse for you. :\
Old 11-10-2007, 05:18 PM   #8 (permalink)
radiocontrolhead's Avatar
Danny
Let it warm up to full operating temperature.
Old 11-10-2007, 07:36 PM   #9 (permalink)
it will still happen throught the day when the car is up to full temp.. i must be the only one with the same problem.. just filled the car up with fresh gas and doesnt seem to do it as much.. maybe bad/old gas from manufacturer?
Old 11-10-2007, 09:20 PM   #10 (permalink)
Danny
Might have been sitting on the lot for quite some time.
Old 11-11-2007, 02:01 AM   #11 (permalink)
SPARTANER's Avatar
my si does this when its cold, but stops when it warms up
SPARTANER is offline   Reply With Quote
Old 11-11-2007, 08:26 AM   #12 (permalink)
gtrice31's Avatar
dealer accomodates with regular gas not premium...
also yeah when its cold itll buck. Hope you read all the problems that this car has with trans etc....
and notice that the dealer often says never heard of such problems etc... many stories on it. g/l a/c sux ass too.
gtrice31 is offline   Reply With Quote
Old 11-11-2007, 09:04 AM   #13 (permalink)
Mark
08Blacex:
I had the same impressions when I first picked up my 08 EX Coupe a couple of months ago. Especially during the first couple of hundred miles. It was an almost imperceptible hesitation, not particular to one gear or one rpm zone. I cannot explain it, although I can offer this advice, and it's served me well over many years and through many new car purchases...
Give it a couple thousand miles to shake out some of these things. Often, vibration type noises and other issues seem to work themselves out as the engine breaks in.
I have 2500 miles on my coupe now and the hesitation is gone - haven't experienced it for some time now.
etcthorne is offline   Reply With Quote
Old 11-11-2007, 10:47 AM   #14 (permalink)
BigT's Avatar
My EX MT does this also slightly. Only if I am between approximately 2000-3500 RPM and get on the gas. I believe it is the i-vtec on the R18. At those revs at low throttle it is using the "economy" cam profile. If you get above those RPMs or if you get on the gas (more load) it will switch back to the standard cam profile for more performance. You may just be feeling this switchover. Just a thought.
BigT is online now   Reply With Quote
Old 11-11-2007, 10:50 AM   #15 (permalink)
JediCodeWarrior's Avatar
Agreed. I have the same problem if I don't let the car warm up. If I let it warm up no problems.
JediCodeWarrior is offline   Reply With Quote
Old 11-11-2007, 10:54 AM   #16 (permalink)
BigT's Avatar
He mentioned that it happens at operating temp.
Old 11-11-2007, 05:19 PM   #17 (permalink)
yeah it is not doing it as much now it has about 375 miles.. i hope its just part of a break in period.. it does get a bit anoying going up hills and such.. thanks for the tips.. i will keep updates as i put more miles on it..
Old 11-12-2007, 04:22 PM   #18 (permalink)
Exclamation Still hesitating
I've got 1800+ miles on my 07 Ex Cpe w/ M/T and it still hesitates. I thought sure maybe it sat on a lot somewhere so I ran Premium through it. That didn't help. I cleaned the MAF sensor. That didn't help. I took it to honda this morning and they said nothing was wrong with it.
Next I'm changing the spark plugs and air filter and removing the 6+ feet of air manifold. No reason for that sh*t, yes the car makes noise when it sucks air into the engine...
MoRed is offline   Reply With Quote
Old 11-12-2007, 07:36 PM   #19 (permalink)
how do they say nothing is wrong? did they drive it and see?? you shouldt have to clean anything out at 1800 miles..plugs and air filter shouldnt need to be touched either.. unless honda has the plugs gaped wrong out of the factory... im not sure what to do...
Old 11-12-2007, 11:57 PM   #20 (permalink)
Kippens's Avatar
My 07 si has the same problem when its not warmed up, after it gets up to temp its fine.
Kippens is offline   Reply With Quote
Official 1.8L 1/4 TIMES!!! Tikolx333 Civic Coupe And Sedan 100 12-18-2010 11:45 PM
Neuspeed Civic Si bluetroll Civic SI 13 12-30-2008 10:58 PM
Official 2007 Honda Civic Si Sedan press release skittleslegend 8thcivic.com Site News 77 11-04-2007 10:23 AM
2008 Civic EX Sedan AT vs. 2008 Mazda 3 s Sport 5-Door cbondhonda Dealership Experience 17 10-28-2007 02:23 PM
