Engine or exhaust issue??? - 8th Generation Honda Civic Forum
Old 06-17-2017, 08:10 AM   #1 (permalink)
Dale
Das_aBle just put it into 1st gear on 8thcivic
Hello all
I have an 08 si with a small issue that my self or mechanic can't seem to figure out. My engine vibrates and exhaust sputters/pops at idle. The car is stock and I have changed the plugs, coil packs, 0/2 sensor, checked for vacuum leaks, and no codes are coming up. The only way I have found to resolve this issue is when I turn the fan or AC on. Air blowing on the engine seems to make it all good again. Everything else is great on the car, it starts, drives, and runs beauty!!
Any input would be greatly appreciated! I have searched the internet high and low but could not find any info regarding this.
Das_aBle is offline
Old 06-18-2017, 06:26 PM   #2 (permalink)
Dale
After spending hours under and inside my engine this weekend, I can conclude
''Twas a valve cover and spark plug tube gasket issue.
Das_aBle is offline   Reply With Quote Quick reply to this message
Old 06-19-2017, 05:31 PM   #3 (permalink)
passyouby just put it into 1st gear on 8thcivic
How'd you figure it out?
passyouby is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
07 Civic intermittent Air Conditioning compressor issue. Ambient temperature related. pjw73nh Mechanical Problems & Technical Chat 0 05-18-2017 10:54 AM
Engine light question. calvooo Mechanical Problems & Technical Chat 2 05-03-2017 06:54 AM
magnaflow cat-back exhaust issue? DraveZ Exhaust Discussion 2 03-06-2017 03:03 AM
Check engine and no heater alphabean11 Mechanical Problems & Technical Chat 3 11-24-2016 12:11 AM
Engine Block Swap alphabean11 Mechanical Problems & Technical Chat 1 10-19-2016 04:28 PM
