87 + detonation
Ok, I understand the Si requires premium fuel. Since I'm not a mechanic or have much experience with pinging, I'm making this thread so I can see what other people have experienced. My two questions are:
1) Have you had detonation in a car before? If yes, what car was it? 2) Have you or someone you know had detonation in the 6th gen Si? or previous Si? 3) Why do some cars adjust to lower octane while others don't? thanks |
#2 (permalink) | |||
Basically, run what you should and dont worry about it. |
#4 (permalink) | |
"The octane rating of a given grade of gasoline is a measure of its detonation resistance. The higher the octane number, the better able the fuel is to resist detonation. Most engines in good condition will run fine on regular grade 87 octane fuel. But engines with high compression ratios (over 9:1), turbochargers, superchargers, or with accumulated carbon deposits in the combustion chamber may require 89 or higher octane fuel." I think people over exagerate how big of a deal pre detonation (spark knock) is though....you would have to have an EXTREME about of spark knock to cause any damage to an engine...just my opinion...almost every vehicle at my work (about 80 vehicles) has spark knock under a heavy load (up big hill) and none of them have ever had a pre detonation related failure (head gasket etc). |
^Detonation is over-rated?? you must not be a tuner. Detonation kills motors.
-detonation and pinging from low octane WILL ruin combustion components. -btw, there is no "pre-detonation". its pre-ignition or detonation, both meaning the fuel ignites because of low octane, high heat, high compression, and not from the timed spark. -pinging in low rpms usually comes from too far advanced timing, or improper fuel grade(87 instead of 93). |
TeamValor, thanks for repeating everything in that article I referenced.
Like I said...."you would have to have an EXTREME about of spark knock to cause any damage to an engine...just my opinion" I'm guessing your tuner makes significantly more hp than a stock civic and is constantly being pushed to the limit. Obviously it would be much easier to have extreme spark knock/pre ignition in your tuner. My point is...in MY OPINION...lower octane isn't going to kill a stock SI...is it good for it? no. will it run to it's full potential? no. What I was kinda getting at was I've seen people ask what they should do about the dealer putting 87 in there SI...and in my opinion...a tank of 87 won't "ruin combustion components". I meant pre-ignition, thanks for correcting me on that, your a saint. |
#12 (permalink) |
wow going off on the topic. Answer the questions i asked in the original post.
People keep giving me the same answer, without any experience... just because a website said so. Detonation and pinging are not happening in my TL so I was wonderig if anyone had any pinging/detonation in their Si. Stick to the 3 questions I asked. thanks |
#13 (permalink) | |
if you think your TL is magical and escaped the issues, then go with it. i have posted with pure knowledge but it seams like all you wanna hear is, "there is a magical fairy in your motor that turns 87 octane fuel to gold that resistes all combustion issues." there i said it. happy now. if you dont want to take anyones advise, go out and fill your poor si up with 87 and beat on it, then come back and tell us how it goes. |
#14 (permalink) | |
| Nitrous 101/FAQ | NewbTuner | Forced Induction And Nitrous | 15 | 10-11-2008 02:42 AM |
| putting reg gas in by mistake in si, using "octane boost" to correct? | Tronixx | Mechanical Problems & Technical Chat | 71 | 11-03-2007 05:43 PM |
| which civic to buy? si gas? | b_waggs83 | Introduction & Pictures | 73 | 06-07-2007 04:41 PM |
| Detonation on 91 Octane | White05X3 | Mechanical Problems & Technical Chat | 18 | 03-07-2007 01:34 AM |
| NOS on Civics | davydany | Forced Induction And Nitrous | 17 | 04-22-2006 10:22 PM |
