AC cuts out / overheats? - 8th Generation Honda Civic Forum
Old 05-19-2017, 09:13 AM   #1 (permalink)
Borisw37 just put it into 1st gear on 8thcivic
2007 Civic SI.
AC would run for 5 minutes then cut out (blowing warm humid air), then cycle back on after some time. The problem is worse if it is really hot outside.
A shop refilled the refrigerant so now the AC does better but still cuts out after 15 minutes on really hot days.
The shop wants to replace the drier and the compressor as the next step
($1000).
Any thoughts, any troubleshooting I can do?
Borisw37 is offline
Old 05-19-2017, 10:11 AM   #2 (permalink)
true72 has their car in neutral right now
Same problem here
I have the same symptoms and found a thread here with quite a bit of info. I already tried the easy stuff like checking freon level and changing the clutch relay. One shop told me it's a bad clutch, but I'm going to try and adjust it before taking it in for a 2nd opinion.
The thread is just below yours. I posted on it yesterday but can't post links yet I guess.
true72 is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 10:35 AM   #3 (permalink)
Thanks, read through your thread. Will go try the relay before letting the shop do their thing.
Borisw37 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
2007 Honda Civic Si, intermittent AC dilemma solved. RoyBoy808 Mechanical Problems & Technical Chat 0 03-06-2017 02:57 AM
2006 Honda Civic R18 AC compressor won't shut off engine stalls aaronsgar5 Mechanical Problems & Technical Chat 3 03-04-2017 11:07 AM
O8 civic w/nav no radiator fans no cold ac air tsuring Mechanical Problems & Technical Chat 1 10-25-2016 09:48 AM
Loud vibration while AC is on Cjd9 Mechanical Problems & Technical Chat 1 10-18-2016 08:51 PM
Another AC issue - High estimate and possible shady shop cdc3rd Mechanical Problems & Technical Chat 1 08-20-2016 11:09 AM
