Vibration&Squeaking coming from right rear suspension assembly - 8th Generation Honda Civic Forum
Old 05-15-2017, 03:59 PM   #1 (permalink)
Aaron Shum
getshum just put it into 1st gear on 8thcivic
Hi,
I got in a car accident 5 months back where car hit a wall on the rear right side. Rim cracked and I'm sure the suspension assembly was damaged as the shop replaced it.
Ever since the replacement, when I lightly brake, the assembly will vibrate(you can hear and feel it). You can also hear it. But when enough braking force is applied it will stop and brake normal with no noise or vibration. The vibration isnt really bad enough to be dangerous, even when im pushing in mountains.
comparing the two sides, it looks like when they replaced it, they installed with a different brake shield (that metal plate behind the rotor).
I've brought it back in 3 times and they cant figure it out. Does anyone have any thoughts on what this issue could be?
09 coupe civic si
getshum is offline
Old 05-16-2017, 11:47 PM   #2 (permalink)
MasterTech21 just put it into 1st gear on 8thcivic
They could've replaced the whole assembly and put a junkyard rotor on there. Maybe that rotor is warped? Just make sure everything is tight.
MasterTech21 is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 08:21 AM   #3 (permalink)
digger1978 just put it into 1st gear on 8thcivic
What exactly was replaced and what was not? Rotors, calipers, control arms, struts, hub assembly??? Have your rotors cut if you can find a place. They sound like they are warped. If you cannot have them cut, replace them.
digger1978 is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Suspension noise kajun Mechanical Problems & Technical Chat 2 01-17-2017 11:46 PM
Rear Upper Control Arm Replacement - 2007 Honda Civic Ex Coupe Sengx1 Mechanical Problems & Technical Chat 2 12-18-2016 01:54 PM
Energy Suspension bushing kit, front bushing on rear trailing arm install aguila88psi Suspension and Brakes 4 11-25-2016 12:53 PM
FA5 HFP front under spoiler replica with Mugen replica sides and rear under spoiler sarb017 Inside and Out 0 10-29-2016 01:22 PM
