Old 10-31-2007, 04:31 AM   #21 (permalink)
sjlarue's Avatar
Call Me Jr Samples @ BR-549
Do you have a sunroof? Maybe it's leaking out of the drain tube, with some greasy residue. But no there is really nothing else back there.
sjlarue is offline   Reply With Quote
Old 10-31-2007, 04:32 AM   #22 (permalink)
sjlarue's Avatar
Originally Posted by volvo9
Wierd, did you happen to get your windows tinted? Anyone spill anything?
I got my windows tinted and they left soap crap all in that same area.
Only other thing I could possibly think of is the black tar crap that's behind door panels holding the plastic moisture shield on.
I'm out of ideas.
That was my thinking until he said he had a coupe.
Old 10-31-2007, 02:49 PM   #23 (permalink)
Mateen's Avatar
Yes I have a sunroof. I've had Sunroof leak on my old car before but the leak always showed up around the sunroof.
Where is the sunroof drain located and what is the rout the water takes to drain?
Mateen is offline   Reply With Quote
Old 10-31-2007, 03:30 PM   #24 (permalink)
sjlarue's Avatar
I Don't quite know, I want to say it's on the passengers side and it runs from the sun roof down the pillar and through to the trunk, but I am more familiar with the regular civic sedan. But if it is clogged , it could leak over the pan that is in there.
That really is a tough place to diagnose what it is. Imediatly I thought door sealer, but since you only have 2 doors...Could be window sealer but that's probably not put on by hand, and wouldn't show up there.
Hope the clean up took care of it, but watch it when it rains again.
Love your avatar BTW.
Old 10-31-2007, 03:59 PM   #25 (permalink)
Brivis's Avatar
Brian
I Googled breakclean, kleanflow & kft313 and got nothing.
The only thing that I could find was wurth. Do they make this product also?
I believe its actually called Brake Kleen
Brivis is offline   Reply With Quote
Old 10-31-2007, 04:16 PM   #26 (permalink)
Mateen's Avatar
Well I'm going to run the water hose on it for a while and see what happens. I'll keep you guys posted. If I see the leak again then I have to make a visit to stealership.
The stuff I used is called BraKleen I believe. I got it at an auto shop (can't remember which one). And yes it does wonders on grease spots.
Old 10-31-2007, 09:57 PM   #27 (permalink)
The McGyver ofall McGyves
portabuddy's Avatar
Bart Koscow
I use it on my pants somtimes when i get grease on them... its extreemly flamable so be carefull, at the last shop i was at we used to play around with it alot...well the forman recived 2nd degree burns to the left hand and i lost the hair on my face and arms...
I dont carry a lighter any more...
portabuddy is offline   Reply With Quote
Old 10-31-2007, 10:48 PM   #28 (permalink)
quality_sound's Avatar
Paul
I had the same stuff but it was from an incompetent tech trying to get my door panel back on after replacing the upper windeow seal. :thumbdown:
However, GooGone spray gel takes it right out and isn't toxic.
quality_sound is offline   Reply With Quote
DIY: Turn Signal Mirrors CameronJr9 Lighting 131 11-27-2008 10:34 AM
How do you mount an amplifier on the back seat? Kroze I.C.E., Electrical, Security, & Navigation 31 09-14-2007 07:07 PM
My fuggin passenger seat broke. amdhunter Mechanical Problems & Technical Chat 44 10-21-2006 11:20 AM
Seat Back Angle BLACKFG I.C.E., Electrical, Security, & Navigation 6 07-01-2006 08:01 PM
