Old 10-28-2007, 12:26 AM   #1 (permalink)
07 si coupe shift knob problem
Im having problems removing my stock si knob for the 07's. Ive seen vids that they unscrew a nut right below the knob but i can seem to find that nut. I just need to remove the stock si knob to install the fd2 boot and knob.
SIck wit it is offline
Old 10-28-2007, 12:29 AM   #2 (permalink)
Litlelev's Avatar
you need to screw the nut under the knob down further, then unscrew the knob
you should really search, this has been covered many times
Litlelev is online now
Old 10-28-2007, 12:35 AM   #3 (permalink)
i cant find it. theres just the linkage arm but nothing directly under the knob to grasp to unscrew.
Old 10-28-2007, 12:44 AM   #4 (permalink)
Litlelev's Avatar
it should be touching the bottom of your knob, your gonna need a wrench
Old 10-28-2007, 05:45 PM   #5 (permalink)
But its not here check it out for urself:
Old 10-28-2007, 05:47 PM   #6 (permalink)
Supreme Pizza!
Izzy's Avatar
O_o? Did you just try unscrewing it?
Sorry to sound lame, but that is the next step...
Izzy is offline
Old 10-28-2007, 05:49 PM   #7 (permalink)
there is no nut to unscrew that the problem lol
Old 10-28-2007, 05:52 PM   #8 (permalink)
Supreme Pizza!
Izzy's Avatar
Well, yeah, so? Unscrew the shift knob (it's just screwed down) as normal. It doesn't magically pop-off. Maybe it's just torqued down and happened to land in the straight pattern...
Izzy is offline
Old 10-28-2007, 06:00 PM   #9 (permalink)
i've tried just to unscrew the knob itseft but the knob wont budge and dont want to break anything buy forcing it
Old 10-28-2007, 08:14 PM   #10 (permalink)
Litlelev's Avatar
you wont break it, get a rubber glove or somethin to grip it and turn as hard as you can
Old 10-28-2007, 08:28 PM   #11 (permalink)
Si Speed 317's Avatar
Dan
^ That will work. Nothing will break.
Si Speed 317 is offline
Old 10-28-2007, 10:11 PM   #12 (permalink)
The McGyver ofall McGyves
portabuddy's Avatar
Bart Koscow
use a strap type filter wrench... it will grip it nicely and not marr the material
portabuddy is offline
Old 10-29-2007, 02:36 AM   #13 (permalink)
thanks! but am i the only is that has encountered this prob??
Old 10-29-2007, 02:40 AM   #14 (permalink)
portabuddy's Avatar
Bart Koscow
well i think so?, mine has a nut on it???.
this is the first case that i have seen or herd of...
Old 10-29-2007, 09:30 AM   #15 (permalink)
Dan
I believe so... Did you get it off?
Old 10-29-2007, 11:43 AM   #16 (permalink)
Duce2k's Avatar
Are you the original owner of the car, if not, then the previous owner must have removed the knob before and didn't put the nut back on. I know some guys actually put krazy glue on the threads so the knob will ine up without having to use the nut, but of course getting it off again will be a pain.
Duce2k is offline
Old 10-29-2007, 12:24 PM   #17 (permalink)
I was wondering the same thing. All 06-08 Si's should come with the nut there. The one in the pic is missing the nut.
DumbasSi is offline
Old 10-29-2007, 01:33 PM   #18 (permalink)
radiocontrolhead's Avatar
Danny
Maybe it was torqued down until the pattern lined up correctly which is why he's having a real hard time removing this. The techs at the dealership that sold him the car are complete morons.
Edit: Usually dealerships will remove the knob so that people will not mess with the car and mar the knob in the showroom. After reading a later post it could be that they lost the nut and the tech was so stupid that he didn't realize that there is a nut that holds the knob in place and used crazy glue or some type of epoxy to hold it in place.
Take it straight to the dealership and show them what they sold you and to get that knob off or put a nut under there like it belongs. Show them other Si's on their lot as well to prove to them that there is a nut. Be sure to stand right by them while they perform this difficult task, that is if they used some type of adhesive.
radiocontrolhead is offline
Old 10-29-2007, 03:43 PM   #19 (permalink)
Dan
^ Then make sure to trip them. Best timing is to probably trip them when they are leaving and all is done.
Old 10-29-2007, 09:31 PM   #20 (permalink)
i am the orignal owner and i am starting to believe that its like glued on there, which is kinda whack. lol. but yea i'll tell the dealer about it when i take my car in for the recall soon cause i really cant take off the knob lol
^SO-CaL SQUAD_UP!^ Dessa_8837 California South 281 05-27-2008 10:04 PM
how much of a pig is your car? weight list webby Garage 20 05-01-2008 01:30 PM
'06 Si shift knob removal problem, need advice VTecVoodoo Do It Yourself Articles 16 12-23-2006 12:47 PM
