Screw the Maintenance Minder System - Page 2 - 8th Generation Honda Civic Forum
Old 10-28-2007, 06:27 PM   1 links from elsewhere to this Post. Click to view. #21 (permalink)
ffswizzlestick's Avatar
You can get synthetic at your dealer, so I would have to say that they wouldn't deny simply based on the fact that you didn't get your oil changed when the wrench popped up.
ffswizzlestick is offline   Reply With Quote
Old 10-28-2007, 06:42 PM   #22 (permalink)
shipo's Avatar
Two points:
  • Please understand that Honda (the company that designed and built your car), and your local Honda dealer(s) (the companies that sell and service cars in the field) are two discretely different corporate entities.
  • In addition, please understand that what your particular dealer may or may not have on hand has nothing what-so-ever to do with Honda's warranty requirements. If you cannot prove that you've changed your oil on time, every time, Honda has every right to deny warranty coverage if a premature engine failure occurs.
shipo is offline   Reply With Quote
Old 10-28-2007, 07:26 PM   #23 (permalink)
But the dealer has a lot to do with whether or not they do the warranty work.
If your engine failed it wasn't because you didn't change the oil when the car said to.
Old 10-28-2007, 07:36 PM   #24 (permalink)
shipo's Avatar
What?
If you have your dealership put in synthetic oil and then you choose to drive a couple of thousand miles beyond the point where the MM suggests an oil change and then suffer an engine failure, Honda can deny you warranty coverage.
Old 10-28-2007, 07:41 PM   #25 (permalink)
Scrodums
You're right. The fact that you didn't change you oil may not have been directly related to the failure of your engine. However, if you didn't follow the warranty procedure, then they could deny you based on that. You would have to really go out of your way to prove that the oil wasn't the direct cause of the failure.
Old 10-28-2007, 09:58 PM   #26 (permalink)
KenB's Avatar
Ken
The car knows. Trust the car.
My Uncle's last car was a turbo diesel Benz that had its own Maintenance Minder on it. Diesels are notorious for being tough on oil. The MM pinged him to change the oil about every 8K depending on how hard it was being driven. He traded it in last Spring with 198,000 mile on the odometer. Never a problem.
My Si sedan has 1700 miles and the MM says I'm at 80%. I'll trust it to do its job.
KenB is offline   Reply With Quote
Old 10-28-2007, 10:19 PM   #27 (permalink)
CiViCDooD's Avatar
people who know nothing about changing oils and all this other hi-tech stuff, MM system FTW!
CiViCDooD is offline   Reply With Quote
Old 10-28-2007, 10:27 PM   #28 (permalink)
J Frost
Funny thing is, I started this thread to see if anyone knew of a checklist, or something to tell me what to do at what mileages so I could save some money and do things myself.... I was talking to the kid at tires plus where I was getting alignment and he printed such a sheet out. I called honda, searched the net and this forum, and asked all of you and Tries Plus randomly helps me. Thanks anyways.
FrostyGT2 is offline   Reply With Quote
Old 10-28-2007, 10:34 PM   #29 (permalink)
07LX's Avatar
Nathan
I have done 2 oil changes in my car so far and I followed the MM... First one came at 5K Honda changed it...Second oil change was scheduled for 5K after that...MM told me 4,238 miles later that I need B1 service.
I looked at the price sheet and what they do I went to Honda talked to them, I told him what I need, oil change and tire rotation..he asked me the other things they looked at and checked and I told him everything is fine. So instead of paying 110 for B1 service I payed 40 bucks for a A1 service.
07LX is offline   Reply With Quote
Old 10-29-2007, 01:49 AM   #30 (permalink)
Kidekat's Avatar
Why is it that everyone thinks they know more about the car than the people who designed and built it?
Because the ones that designed and built it would be broke if you didn't buy a new car every few years.
I don't trust the maintence minder pure an simple. I feel it it more for super busy lifestyle with oil changes very low on the priority list.
Imagine if they used it on airplanes, rather than going by hours of flight.
Kidekat is offline   Reply With Quote
Old 10-29-2007, 02:27 AM   #31 (permalink)
shipo's Avatar
Like it or not there is a huge body of scientific evidence that proves that the OLM systems currently being used my many manufacturers are very effective.
Your analogy to airplanes is a bit odd. Modern FADEC controlled airplanes do in fact use such predictive systems; however, trying to retrofit such a system to the 1945 vintage technology O-300 that I occasionally fly behind just isn't practical. That said, I think such an idea is wonderful.
Old 10-29-2007, 11:29 AM   #32 (permalink)
The MM does use the amount you drive actually.
Old 10-29-2007, 11:32 AM   #33 (permalink)
Scrodums
Here you go: Maintenance Schedule and Pricing Menu
Old 10-29-2007, 12:44 PM   #34 (permalink)
J Frost
thanks yodums, that is all i was looking for
Old 10-29-2007, 03:50 PM   #35 (permalink)
ryker's Avatar
Originally Posted by Yodums
Again, not many people on these boards are using the recommended oil. Why would I follow the maintenance minder if I'm using an oil such as Amsoil XLF? Conversely, what about the people who are running a forced induction setup?
I agree that the MM is suited for dino oil and a high quaility synthetic oil would be able to go well beyond the MM limits. The debate is that most people like to follow a 3k or 5k number and that is typically WAY too low for dino oil.
Forced induction would be better suited at establishing a baseline with UOA. Once again many factors would be involved. Daily driver that doesn't use WOT all the time verse a weekend drag car...
ryker is offline   Reply With Quote
Old 10-29-2007, 03:54 PM   #36 (permalink)
ryker's Avatar
Originally Posted by shipo
I was working at Mercedes-Benz when they were developing their OLM system for synthetic oil, in the end the engineers determined that there was just a single metric that needed to be measured to determine when the oil should be changed. The metric? The number of liters of fuel used since the last reset. FWIW, BMW determined the same thing and that is the only metric they use as well.
Fuel consumption is based on engine load and average engine speed. Since the modern engines keep pretty constant temps and have a pretty clean air filter. Fuel consumption would be a good method ---- and since BMW and MB did the lab testings..
Old 10-29-2007, 04:00 PM   #37 (permalink)
ryker's Avatar
That is NOT an offical Honda list. It is simply a stealerships method to get more work.
I would think a moderator would be aware of this or at least edit that posting since it is misleading.
Old 10-29-2007, 04:09 PM   #38 (permalink)
shipo's Avatar
Good catch. I was too lazy to follow the link before. An oil change at 3,750 miles in this day and age. Absurd! That dealership and all dealerships that recommend such a service ought to be severely chastised for their fleecing of the driving public. Grrrr.
Old 10-29-2007, 04:32 PM   #39 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
20,000km and already 4 oil changes. That's normal, no? I never let it go below 20%
Old 10-29-2007, 04:38 PM   #40 (permalink)
Scrodums
Sorry for the misinformation, but being a moderator doesn't necessarily mean I automatically know more information than a regular user.
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/62419-screw-maintenance-minder-system.html
Screw the Maintenance Minder System - 8th Generation Honda Civic Forum This thread Refback 12-06-2007 02:55 PM
Nitrous 101/FAQ NewbTuner Nitrous Oxide 15 10-11-2008 02:42 AM
Two General Questions Special Ringpop Civic SI 2 06-02-2007 12:57 AM
Nitrous 101 FG*SQUAD Nick Turbocharging 22 05-26-2007 02:50 AM
Maintenance minder and synthetic oil question... Paradox Lost Mechanical Problems & Technical Chat 17 02-14-2007 09:59 PM
honda should recalibrate maintenance minder CivicWithNav Civic SI 8 10-27-2006 06:38 PM
