Old 04-19-2006, 12:36 PM   #1 (permalink)
Nathan's Avatar
Engine Noise at 6000 RPMS
After 6000 RPMs my engine makes a metallic rattiling noise. It is def. coming from the engine, and is a "whizzing/shaking" noise. I have searched about this and I can't find much information.
My car sounds alot different then this.
http://youtube.com/watch?v=I9LFJTu5x...rch=si%200-100
I assumed this was the vtec, but lately i'm thinking it could be something else. Most people say they can tell when the vtec activates by sound or speed, but I cant.
Does anyone else experience this with their Si's?
Nathan is offline
Old 04-19-2006, 01:28 PM   #2 (permalink)
2RotorMotor's Avatar
Are you putting premium gas? It could be knocking... I would have that checked out by the dealer..
2RotorMotor is offline
Old 04-19-2006, 04:18 PM   #3 (permalink)
STIG: a tamed race driver
Jrfish007's Avatar
I don't think you should here VTEC kick in, and the new i-VTEC systems activate at different points depending the cam phase (timing) that is being used at that moment. Anyway, take it to the dealer.
Jrfish007 is offline
Old 04-19-2006, 04:22 PM   #4 (permalink)
WEll, you SHOULD hear vtec kick in at 6k rpms at all times.... When I removed the cat-back even at 35% throttle, you were able to hear vtec kick in nicely at 6k. All Ivtec does is adjuct cam timing. The actual switching over of cams is done at 6k rpms...
Old 04-19-2006, 04:51 PM   #5 (permalink)
Jrfish007's Avatar
Do Si's have a secondary intakes? I know my '94 GSR you could hear the secondary open up at higher RPMS, but it really just made things more aggressive sounding. And yeah, I would expect that you would hear something with aftermarket, I was talking stock. It seems to me VTEC should kick in before 6000 RPMS. But I don't have a manual for the new Si yet, so I can't say for sure.
Old 04-19-2006, 04:53 PM   #6 (permalink)
Jrfish007's Avatar
In fact now that I think about it, that sounds like it is probably one of the butterflies in the secondary intake not opening properly, I've heard of that happening on GSR's
Old 04-19-2006, 08:30 PM   #7 (permalink)
Minister of Discord
Janizary's Avatar
Gas thread Nazi
Jrfish007, you definitely hear the vtec change over at 6K in the Si. There is nothing gradual about it :)
Many of the drive reviews of the Si make mention of the very noticable change.
Nathan, there was some mention of that metallic rattling sound over a ToV, but it was a while back. I can hear it now and then, but not every time.
Janizary is offline
Old 04-19-2006, 09:11 PM   #8 (permalink)
yeah i have this same "problem" its on the tov forums as well. its supposedly normal. if you have your windows rolled up and sunroof closed you will hear it. its supposedly the timing chain, and according to the people on tov it is completely normal.
kurdtkobain87 is offline
Old 04-20-2006, 08:57 AM   #9 (permalink)
Jrfish007's Avatar
I'm still not convinced that the VTEC kicking in. Like I said it's probably the secondary intakes. It just doesn't make sence to me, I mean cars that rev far higher than the Si, have VTEC engage much lower than the 6,000 RPM's. For instance my GSR revved to 8200 RPM, but VTEC kicked in at 4200, same with other cars like the RSX-s and S2000, it doesn't make sence to me that they would make the Si so high....
Does anyone have a Helm manual yet, it should say in there
Old 04-20-2006, 09:12 AM   #10 (permalink)
Its a fact that vteck kicks in at 6K rpms... the tov civic dropped the point till 5.
Old 04-20-2006, 10:35 AM   #11 (permalink)
Jrfish007's Avatar
Yup... your right.
So does the Si have dual stage intake or not then?
2006 Civic Engine: I-VTEC webby Garage 8 10-15-2007 11:54 PM
Kind of interesting - Honda Chronology 1946-2005 webby Water Cooler 4 10-04-2006 09:39 PM
engine rattle above 5500 rpms billz Mechanical Problems & Technical Chat 18 04-09-2006 01:03 AM
2006 Honda Civic Engine Information webby Garage 4 08-04-2005 01:53 PM
2006 honda world news webby Garage 0 07-25-2005 09:31 AM
