shifter cable bushing help!
Ok so all my cameras are dead ofcourse but on the TWM cable bushings once they are installed does the clamp ring you put in the little groove on top stick out and it wider than the actual busing itself? it seems like this ring used to keep it from falling through the transmission line, although snapped into place perfectly... is very big.
Sorry ill post pics later if you guys dont understand |
#2 (permalink) | |
:p*** I <3 Hikki
205whp 147tq :D
ok also for the smaller bronzoil bushing the only way i could get it to go on was for the small end through the drive cable ring first and clip it on the side clasest to the motor is this going to be a problem? i dont see why it would as long as its in place, and also wat was the screen like sandpaper that came with the cable kit from TWM for?
#4 (permalink) | |
:p*** I <3 Hikki
205whp 147tq :D
I dont know anything about the sandpaper because I have the corsport bushing set.
no i got it on fine, its just you know how one side of the metal busing is bigger than the other? like a lip so it will catch when it fits into the trans line? well in order to get it on the post i had to slip the side without the lip slosest to the motor and clip thant same side, then one with the lip is on the right sight if looking down at it from the engine bay.
#6 (permalink) | |
:p*** I <3 Hikki
205whp 147tq :D
thanks ryan for the pic... i know the c clip goes in the little grovve on the busing... but if you look at the pic of your smaller bushing, mine is directly reversed with the groove on the other side. I havent noticed any issues though 40 mi drive to work today, feels great btw i dont see how mine just being opposite could cause any damage some1 please correct me if im wrong
#10 (permalink) | |
:p*** I <3 Hikki
205whp 147tq :D
#11 (permalink) | |
:p*** I <3 Hikki
205whp 147tq :D
#13 (permalink) | |
:p*** I <3 Hikki
205whp 147tq :D
#15 (permalink) | |
:p*** I <3 Hikki
205whp 147tq :D
| DIY part II: Cable Shifter bushings (Big Pictures inside) | atruhondagrl | Transmission | 79 | 09-28-2008 11:38 PM |
| 2007 Civic Shifter Cable Bushings! | TWM Performance | TWM Performance Short Shifters | 23 | 04-26-2007 02:55 PM |
| TWM Shifter Cable Bushings | TWM Performance | TWM Performance Short Shifters | 0 | 03-19-2007 05:14 PM |
| twm's new shifter cable bushings (bronzoil) | acrobles | Garage | 3 | 03-02-2007 02:54 AM |
