Vibration underneath?
When I am on partial throttle like lets say half and up at around 4k rpms i let off, it back down and gets that loud deep resonating growl from the aftermarket exhaust which sounds sooo sexy btw if you know what im talking about... anyways once it starts to resonate i hear a slight vibration from under the car, directly underneath the center console it seems. I believe this is just the pipe rattling from when the car is backing down... never noticed it til' this morning ofcourse i have not been listening for it, I also notice a whistle when on partial throttle which I assume is from the intake getting air. I even noticed this in my 07 EX before my SI
any thoughts? Josh |
I am the Juggernaut!!!
I see a broken flex-pipe in your future from your DCRH. The flex-pipe issue has been around since 2002 with the DCRH & that is why I went the JRRH on my EP3 & now I'm running the BCRH on the FA5.
Supposedly DC "fixed" the flex-pipe issue but the DCRH looks the same to me. How long have you been hearing this sound from underneath your car? Was this sound present before the DCRH was installed?
dont necessarily need a lift. just jack stands.
BTW, if it is broken, get it welded and get a torque dampener. that should stop teh engine from moving soo much, then there wont be too much of a strain on the flex pipe. or get that flex pipe cut out and a longer one welded in place. |
I just noticed this sound this morning... so i dunno i guess it could be broken, will DC not fix this problem if thats the case? and it seems lke all this cutting and bitchering this RH seems kind of expensive to make a cheep ass header better i knew i should have went BCRh
Josh |
Did you fill out the warranty card & mail it to DC? If you did that then DC should fix or replace your RH for free since you've only had it for three months.
#11 (permalink) |
ok and what the hell do i do in the meantime while they have it... am i without a car? and what about installation and uninstallation? this friggin blows!... also is it bad to drive around with a busted flex pipe for a day or too (100miles or so) until i get the situation figured out?
#13 (permalink) | |
#14 (permalink) | |
| Intermittent, Varying-intensity vibration in my '07 Si Sedan | ABQSI | Mechanical Problems & Technical Chat | 6 | 04-14-2008 04:38 PM |
| M/T vibration | xmontx | Mechanical Problems & Technical Chat | 4 | 09-24-2007 11:47 AM |
| Vibration in clutch pedal? | SonicK20Z | Mechanical Problems & Technical Chat | 9 | 09-10-2007 12:04 AM |
| Front Passenger Wheel Vibration | Case3440 | Mechanical Problems & Technical Chat | 6 | 07-14-2007 11:12 PM |
| clutch pedal vibration when shifting | stoke | Mechanical Problems & Technical Chat | 4 | 07-05-2007 07:50 PM |
