Old 10-08-2007, 09:04 PM   #1 (permalink)
New Steering Wheel Not Centered
Hi all,
I recently had a Honda Dealer install a new steering wheel for my 06 Civic Si because I managed to damage the leather on the old one beyond repair. Afterwards, I noticed that the steering does not feel centered, even on flat roads.
I've been looking online on how steering wheels are installed and from what I understand, center the steering wheel is not an exact science but more of just eyeing it.
Could you guys help me out? Is it possible to get a steering wheel aligned perfectly centered, or is this a common problem that is difficult to overcome?
P.S. I've had my steering wheel aligned twice since I've owned this car, the last time in the past 5 months.
yuphorix is offline   Reply With Quote
Old 10-08-2007, 09:35 PM   #2 (permalink)
````````1dsdqy68qQ
Chuck D23 is offline   Reply With Quote
Old 10-08-2007, 09:38 PM   #3 (permalink)
Brodie
atruhondagrl's Avatar
Take it to another dealer. Maybe. Erg. Not too sure what to say man.
AWD is RWD with training wheels.
atruhondagrl is offline   Reply With Quote
Old 10-08-2007, 09:49 PM   #4 (permalink)
4door's Avatar
tilt your head
4door is offline   Reply With Quote
Old 10-08-2007, 10:12 PM   #5 (permalink)
SIcivic07's Avatar
Dan the DIME slayer
well...for the paast couple months, ive had what seems to be a mis alignment with my wheels..even on flat roads, ill have my steering wheel straight as an arrow, and the car goes right...people have told me to go get the alignment to see if it fixes my problem, but i dont feel like spending the 70 bucks to get it done...other say i may have a mis aligned steering wheel, and it may not be an alignment at all...so im stumped on what to do, so the next time i go to the dealer for something, ill have them check it out.
SIcivic07 is offline   Reply With Quote
Old 10-08-2007, 10:16 PM   #6 (permalink)
Brodie
Blame the roads. I do. All the roads in VA and DE seem to lean down (to drain better) really bad. I hate it. For a while, I thought it was the car.
Old 10-08-2007, 10:59 PM   #7 (permalink)
Hey SIcivic07,
What I did was I bought a lifetime alignment from Firestone. It cost me $150, but you can take it in as many times as you like. I've had my alignment done twice in a year already and their computer has shown that both times the alignment was off by a decent amount. If you have a firestone near by, you can try seeing if they have that deal, but it's definitely worth it since a single alignment can cost anywhere from $60-70.
Old 10-08-2007, 11:03 PM   #8 (permalink)
WHOcaREs05050
Whocares05050's Avatar
Originally Posted by 4door
tilt your head
Whocares05050 is offline   Reply With Quote
Old 10-08-2007, 11:22 PM   #9 (permalink)
radiocontrolhead's Avatar
Danny
You don't have to remove the steering wheel to replace the leather wrap.
Old 10-08-2007, 11:49 PM   #10 (permalink)
After searching online, it seems that this is a common issue when installing new steering wheel. Apparently, either due to manufacturing imperfections or just installers incompetence, a new steering wheel can be off center.
Apparently doing an alignment can fix that by using a piece of equipment to center the steering wheel and then adjusting the tie rods to compensate for the misalignment.
There is some debate on whether this is considered a standard procedure or not. I do see one sort of issue. If you adjust the tie rods to compensate for the misalignment, would this affect the turn radius of a car. I'm not mechanically knowledgeable about these things so I was wondering if anyone else would know.
Old 10-09-2007, 03:56 AM   #11 (permalink)
Firestrife's Avatar
Keenan
yes they can work on it when getting an alignment and so but you have to request it otherwise they wont do it.
Firestrife is online now   Reply With Quote
Old 10-09-2007, 03:59 AM   #12 (permalink)
TOMMIELOEKO's Avatar
Location: 15bucks lil man, put that sh*t in my hand!!!!!!!!!!
Shake & Bake!!!!
tilt your head
nah.. you need to drive with a gangster lean!!!
TOMMIELOEKO is offline   Reply With Quote
Old 10-11-2007, 05:16 AM   #13 (permalink)
sjlarue's Avatar
Call Me Jr Samples @ BR-549
Originally Posted by yuphorix
Hi all,
Happens all the time, that's the problem with a spoke that isn't keyed, or slotted. While it is almost imposable to get it perfectly centered, it should be close.
How to test:
1st test. Turn your wheel all the way to the left make a note of where the "H" is pointing is then turn it all the way to the right and make note of position. It should be equidistant from center on both sides. Meaning that if it is pointing to the left 30 degrees, it should be close to 30 degrees to the left with in 5 degrees. This is true for all Honda makes and models other than DXs. Don't ask me why, I can't figure it out myself.
2nd test. Get on a flat road. The 3 degree slant shouldn't matter, because you are checking the steering wheel, not the alignment. But if it makes you feel any better, get on a country road and straddle the lanes (!!!unsafe!!! Don't say I didn't warn you). move steering wheel so that the "H" is straight up and down. If the car moves, not drifts, one way or another it's suspect. Get back to center and let go of steering wheel, if "H" is straight up and down your OK if it points right or left, get it fixed.
BTW DON'T FIX IT YOURSELF. Unless you like getting hit with a pillow at 200 miles per hour. If you do...naughty, naughty, naughty.
sjlarue is offline   Reply With Quote
Old 10-11-2007, 08:34 AM   #14 (permalink)
Brivis's Avatar
Brian
Brivis is offline   Reply With Quote
Suspension Theory/Chat Thread Highrev1 Suspension and Brakes 450 10-28-2008 01:04 AM
Tires, Camber, Caster, Toe!!! Highrev1 Suspension and Brakes 23 06-24-2008 11:08 AM
How to achieve the tightest turns? How much do you turn your steering wheel? dlux200sx Civic SI 10 10-24-2006 07:43 PM
Is your Si steering wheel centered? augydog Civic SI 13 09-20-2006 09:34 PM
