AC smells like soured milk?
when my AC is on it smells like dogshit in my car, dunno what to do. only thing i can think of is when we floured my friends car back in Highschool and it got in near the compressor and into the vents.... hwo to get rid of this?
thanks, Josh |
Its most likely mold, when you run the AC and then turn it off there is still moisture inside. Thats why its better to run the regular fan after you AC to take away the moisture
yeah its most likely the Flour, there is a cabin filter maybe you can replace it and see it if helps? |
#8 (permalink) | |
#10 (permalink) |
Camry Loverz
With the fan the green light for the AC isn't on.
#11 (permalink) |
I have had the same issue with a 98 CR-V and a 2006 Pilot. There are a few products out there that you spray into the intake vent on the outside of the car at the bottom of the windshield that will get rid of the smell. On the Pilot I used a product called "MOC A/C Odor Treatment", which one of the parts counter guys gave me at my local Honda dealership. I used 1/2 of the 5 ounce spray can just prior to replacing the cabin air filter. It worked really well. The contact number for MOC is listed as 818-896-2258 on the can. Hope this helps.
#13 (permalink) |
I talked to a mechanic and he said the best thign to do is turn the AC off a few minutes before you turn the car off. This lets some of the water from the AC drip out. Another thing he said to do is make sure to hit the recirculate button to close the vents on your car if you plan on storing it for extended periods of time. Lots of bugs and mice can enter through these vents, thus leaving a bad small or even possibly damage wiring.
| just in case you need every cereal type from the 80's | webby | Water Cooler | 16 | 12-09-2007 04:28 PM |
| spilled milk on seat and floor carpet | Stealthcivic | Detailing | 21 | 10-22-2007 12:14 PM |
| Stoner's Invisible Glass, smells like Windex? | asdf | Detailing | 11 | 08-10-2007 09:50 PM |
| Milk Stains | goofygamer | Detailing | 17 | 02-18-2007 11:50 PM |
| a gallon of milk in 41 seconds | webby | Water Cooler | 5 | 01-06-2006 04:16 PM |
