Dropped down 2 gears and ended up at 7.5k rpms... - 8th Generation Honda Civic Forum
Old 10-06-2007, 04:31 PM   #1 (permalink)
Civicn33b's Avatar
Josh
I am reflashed so my limit is higher but still... do you guys think im ok, everything seems fine and dandy
Civicn33b is offline
Old 10-06-2007, 04:32 PM   #2 (permalink)
Chase's Avatar
Chase
OMG 7500 RPM!!! Dude your car is GOING TO EXPLODE ANY SECOND! The engine was not designed for such high speeds... Dude your lucky you didn't leave pistons and rods on the road... Dude....
Chase is offline   Reply With Quote
Old 10-06-2007, 04:36 PM   #3 (permalink)
F-1 Si's Avatar
Peter
Are you kidding?
F-1 Si is offline   Reply With Quote
Old 10-06-2007, 04:37 PM   #4 (permalink)
aki
aki's Avatar
Semi-Si Sedan Hater
You crossed the limit buddy. I know it shows the redline clearly as 8000 on your tach, but don't let those Honda engineers full you--it's 7.2k. And since you're 300 RPM over you can expect your pistons to have hairline cracks. Unfortunately you won't notice them immediately, but in about a year or so your engine will give out. The ECU has also permanently recorded your abuse (short of replacing it with a new one, of course), so if you ever take it to the dealership you're not going to get any warranty backing.
aki is offline   Reply With Quote
Old 10-06-2007, 04:55 PM   #5 (permalink)
sgtpruitt's Avatar
Tim
sarcasm is a dangerous weapon
you are ok my good man.
sgtpruitt is offline   Reply With Quote
Old 10-07-2007, 02:24 PM   #6 (permalink)
Civicn33b's Avatar
Josh
wow thanks to all of the ********, my fault wont post any more ?s
Civicn33b is offline   Reply With Quote
Old 10-07-2007, 02:39 PM   #7 (permalink)
Hayabusa's Avatar
Just PM your questions to me in the future. I will ask them. I don't get upset over forum posts on the internet.
Hayabusa is offline   Reply With Quote
Old 10-07-2007, 02:44 PM   #8 (permalink)
Litlelev's Avatar
im not tryin to be mean but u got a reflash, didn't even hit the stock redline and are nervous you revved too high?
What reflash?
Litlelev is offline   Reply With Quote
Old 10-07-2007, 02:44 PM   #9 (permalink)
mO 64 StAnG 06's Avatar
Actually, this "could" be bad...
Depending how quick he let off the clutch, jumping that high and quick in the RPMs "could" damage something. But most likely nothing happened dude.
Since everyone else left sarcastic posts, I can't... ********.
mO 64 StAnG 06 is offline   Reply With Quote
Old 10-07-2007, 02:53 PM   #10 (permalink)
F-1 Si's Avatar
Peter
What could actually happen if he spun up to 7500 rpm too quickly? Please explain in detail. Maybe a little burned clutch?
Especially since his stock rev is 8200 & he has had his ECU reflashed.
Old 10-07-2007, 02:56 PM   #11 (permalink)
sgtpruitt's Avatar
Tim
hey my post wasn't sarcastic
I was the protagonist this time
Old 10-07-2007, 03:00 PM   #12 (permalink)
Scrodums
It'll be rough on the transmission and especially the motor mounts.
Old 10-07-2007, 03:00 PM   #13 (permalink)
You just answered your own question...
Old 10-07-2007, 03:07 PM   #14 (permalink)
F-1 Si's Avatar
Peter
I hope our motor mounts are not that weak.
If this is the case you better not strap your car down to a dyno; talk about torque flex and twisting the motor mounts.
Those of us who go F\I should look into the weak motor mounts.
Would you say it's the metal the mounts are constructed of or the factory rubber isolators?
Is there a thread that this was discussed in? Or any independant tests that were performed?
I'm not being sarcastic, I just want to read more about it.
Thanks
Old 10-07-2007, 03:08 PM   #15 (permalink)
F-1 Si's Avatar
Peter
BTW what 2 gears did u drop?
Old 10-07-2007, 10:01 PM   #16 (permalink)
Civicn33b's Avatar
Josh
5th down to 3rd
Old 10-07-2007, 10:12 PM   #17 (permalink)
F-1 Si's Avatar
Peter
5th down to 3rd
Well while waiting for answers to my questions, Dude it's not that bad.. Maybe you did some clutch glazing. No motor mount damage I'm sure. Did you check you spark plugs? If you think you did damage either do a leak-down compression test or get one done to make sure your within factory specs.
I've been building honda's since the mid 80's it's happened to me before, much more extreme then your case.
Let me know the outcome.
Old 10-07-2007, 10:13 PM   #18 (permalink)
hyperluv's Avatar
God is Love - So STOP Hating
hyperluv is offline   Reply With Quote
Old 10-07-2007, 10:38 PM   #19 (permalink)
'06Siguy's Avatar
Scott
dude, your golden. The car is made to rev like that. Many times I'll go from 6th to 3rd, and hit about 7500 rpm's...but I keep it floored to 8100 until i shift to 4th.
'06Siguy is offline   Reply With Quote
Old 10-07-2007, 10:42 PM   #20 (permalink)
Gonzo's Avatar
Your engine is just fine but downshifting to 7.5 like that without rev matching will be rough on the rest of your drivetrain. Be sure to rev match! Your transmission will thank you and it's gratifying. Once you master it you can move on to heel toe.
Gonzo is offline   Reply With Quote
