Underinflated tires
I think after having my tires check at the Honda dealer when I went in for my first oil change, Honda forgot to inflat my tires or something. Before going to the dealer for the oil change, I swear I had at least 32 PSI on all four tires. I checked it yesterday and I found it was 25 PSI for all four tires. I must have driven over 2 weeks at this level. The tires looked fully inflated and only thing that made me check the tires was when the tires squeaked a bit during high speed turns. I'm just wondering if my rims could be damaged by driving at 25 PSI? I know it's bad for the tires.
#3 (permalink) | |
When are you getting your readings? The best time to properly get a reading would be first thing in the morning with no load on the tires. Try doing it 2-3 days straight every morning prior to driving. |
#4 (permalink) | |
What is everyone running their tires at? I know the factory say 32 up front and 28 in the rear. not sure why they should be lower in the back than the front but I guess Honda knows best.
How about 34 psi all around? Would that hurt or possibly gain a tad of mileage on long highway trips? |
I checked my tires in the morning and during that time I haven't driven the car for over 12 hours. I'm just somewhat worried because I did drive over some short mini incline/declines on small bridges at about 40-45 miles per hour and it makes your car almost fly in the air. The part when it goes back into the flat ground worries me... anyone here think it might have damaged the rims? Just to let you now again, all four tires looked fully inflated even at 25 PSI.
#8 (permalink) | |
Discussion: Engineers vs Sales Marketing Towards the bottom of the first post... How to Introduce Yourself to Your New Civic Having a full weeks course in just tires(yes, there is THAT much to learn about tires ALONE!) I have no clue what the stock tire psi is but i'm sure it's about 40psi. 34will be fine so will 32 and 28 is getting kind of low... Summer tires max out at 51psi, so the regulars are probably what? 48ish? |
#9 (permalink) | |
#11 (permalink) | |
#14 (permalink) | |
Stephen "Vince" Carter
to the OP, your worried about nothing, not likely that you damaged anything other than you've been fined 2 man cards for not checking your tires. |
#16 (permalink) |
I always have pumped air to 33 PSI on the gauge because when you remove the air pump you'll lose about 1 PSI in the tires. Anyway, I went as fast as 90 miles per hour on my 25 PSI tires and they performed great except for the turns, it squeaked a bit. I have driven on a complete flat before with my old tires with my old car about 15 miles and even that, I couldn't see visible damage marks on the outside of the tire. If you're wondering, I'm using my OEM 16" Goodyear Eagle RS-A tires. I discovered that my tires aren't as smooth after inflating back to the correct tire pressure. I wonder if it was caused by the underinflation.
#18 (permalink) |
Dude, I'm not a senior. I'm in my 20's. I don't know if they actually underinflated my tires, but right after the oil change and when I took my car to highway speeds while turning, the tires squeaked. Tires squeaking usually means underinflated tires.
| *8thCivic Tire Help 101* | CrackThatTec45 | Wheel And Tire Upgrades | 49 | 06-15-2008 10:58 PM |
| New Tires: Federal SS595 | Mikey6p | Wheel And Tire Upgrades | 4 | 08-25-2007 03:58 PM |
| 8k and the tires are gone!! | VdoManZ | Wheel And Tire Upgrades | 13 | 03-19-2007 10:51 AM |
| Replacing Front Tires | HAQER | Wheel And Tire Upgrades | 3 | 02-24-2007 03:52 PM |
| Making an EX look like a DX (snow tires w/pics) | GlennS | Wheel And Tire Upgrades | 2 | 02-10-2007 04:46 PM |
