whirring engine noise
i have a si.
so from 8200rpm on second, i either mis-shift into first or hit third with it popping back out. i'm not sure exactly what i did b/c it happened so fast, but the rpms jumped pass 9k rpm. i hit the clutch and put it in neutral as fast as i can, fearing the death of my car. so my car has started to make this whirring sound. it's audible under 3k rpm and happens only when the gas is engaged. the pitch of the whirring sound gets higher if you're in a higher gear. i'm thinking it's a serious internal engine problem. any ideas on what it could be before i take it to the dealer?
the whirring noise is very similar to the one on this thread. listen to the whirring sound near the end of both sound clips.
I mis-shifted... |
the diagnosis is main shaft bearing; it'll be replaced tomorrow under warranty.
so i searched and found this: http://www.hondacivicforum.com/m_377138/tm.htm it looks like a very fun diy, but i'll let the dealer handle it =D |
| ECM Technical Information and Tuning Capabilities | blueroadster | Forced Induction And Nitrous | 77 | 08-28-2008 08:57 AM |
| Driver side brake noise | AbsoluteGG | Mechanical Problems & Technical Chat | 13 | 08-30-2007 12:05 PM |
| DownShifting!?! | roadrunner1659 | Driving Experience | 88 | 02-08-2007 03:56 PM |
| link to some facts about the 8thcivic | C2i0v0i1c | Garage | 3 | 07-12-2005 12:52 AM |
