Pulled a CEL
Guys,
I filled up with Marathon this morning and pulled a cell moments later. I also recently switched from a DC race header to a Random Tech cat without removing the defouler. I'm beginning to think it is not the gas but the fact that I did not remove the defouler. Is it possible that the sensor is not getting enough air to read properly? Any thoughts? |
#5 (permalink) | |
You are planning to go all motor, buy the tools you need.
If you haven't already got a FSM, get one. And a ScanGauge II only costs $169. It's like you are working on your car with a crescent wrench. (And check if there's a CHECK FUEL CAP message on the information display.) -mr. bill |
#10 (permalink) | |
Thanks Mr. Bill
#12 (permalink) |
Guys you were right! But keep reading!
I clicked the gas cap and disconnected the battery and then reconnected and something magical happened! I freaking swear I gained 10HP by just reseting the ECU. So I'm thinking it's a fluke or that it will go away right. I drive for 30 minutes and stop and restart the car, SAME POWER! I did that 3 times and it still runs like butter and all of the shifts are perfect. For those of you thinking that it is psycho somatic I am telling you it is NOT! Remember I switched to the RT AJP cat from a DC race header and I think the ECU had to be reset for it to adjust to the new mod. Now I have a ton more low end torque too! I'm not really sure why it shifts better, but it does almost perfectly. All because of a gas cap and your help! If you do a mod I highly recommend reseting the ECU guys! I'm in love all over again! Hot Damn! |
| Got pulled over for tint this morning... | bikinpunk | Water Cooler | 36 | 08-06-2008 12:01 AM |
| Cell Phone Car charger not working in either power outlet | chelmsford | Mechanical Problems & Technical Chat | 3 | 05-10-2007 07:22 PM |
| If you get pulled over. | GeezerSi | Water Cooler | 3 | 03-08-2007 11:45 AM |
